Partes
No se requieren partes.
Flip the computer over so that it is upside down. Slide both latches away from each other (towards the outside).
  • Flip the computer over so that it is upside down.
  • Slide both latches away from each other (towards the outside).
  • Push the battery out with your fingers.
  • The actual battery is not shown in the photograph.
Agregar Comentario
Remove the two screws on the underside of the case.
  • Remove the two screws on the underside of the case.
  • These screws should should have a keyboard "K" symbol next to them.
Agregar Comentario
Locate the little tabs above the INSERT, F10 and F1 keys, and between the F5 and F6 keys. Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs. Once all four tabs have been released, the top half of the keyboard should be free.
  • Locate the little tabs above the INSERT, F10 and F1 keys, and between the F5 and F6 keys.
  • Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
  • Once all four tabs have been released, the top half of the keyboard should be free.
Agregar Comentario
Pull the keyboard out at a 45 degree angle and place it upside down on the scroll pad. Pull the wide ribbon cable laterally from its socket on the motherboard.
  • Pull the keyboard out at a 45 degree angle and place it upside down on the scroll pad.
  • Pull the wide ribbon cable laterally from its socket on the motherboard.
Agregar Comentario
Conclusión
Steven
Miembro Desde 24/06/10
32 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 2-9, Johann Summer 2010 Miembro de Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 4,720
