Saltar al contenido principal
Asus Transformer Pad TF103C Speakers Replacement
Qué necesitas
  1. Asus Transformer Pad TF103C Speakers Replacement, Speakers: paso 1, imagen 1 de 1
    • Shut down your tablet before beginning the repair.
    • Insert the plastic opening tool on the side of the tablet.
    • Gently pull upwards and carefully pry open the tablet.
  2. Asus Transformer Pad TF103C Speakers Replacement: paso 2, imagen 1 de 1
    • Slide the tool around all four sides of the tablet while gently pulling the tool up.
  3. Asus Transformer Pad TF103C Speakers Replacement: paso 3, imagen 1 de 1
    • Remove the back cover once you have loosened it from the tablet. Set the back cover aside.
    • Rotate the tablet to match the picture.
  4. Asus Transformer Pad TF103C Speakers Replacement: paso 4, imagen 1 de 1
    • Carefully unplug the rainbow cable from the motherboard.
  5. Asus Transformer Pad TF103C Speakers Replacement: paso 5, imagen 1 de 1
    • Use the plastic opening tool to carefully pry the battery out from the frame.
  6. Asus Transformer Pad TF103C Speakers Replacement: paso 6, imagen 1 de 2 Asus Transformer Pad TF103C Speakers Replacement: paso 6, imagen 2 de 2
    • Use the JIS #000 screwdriver to remove the four screws.
    • Keep the screws together and organized. (Label the screws, if necessary).
  7. Asus Transformer Pad TF103C Speakers Replacement: paso 7, imagen 1 de 1
    • Take the ground wire out from the top of the TF103C-L (left) speaker.
    • If you pull on the wire too much it will break off.
    • If you break the wire off you can solder it back on.
  8. Asus Transformer Pad TF103C Speakers Replacement: paso 8, imagen 1 de 1
    • Remove the tape and unplug the wire that is connected to both of the speakers.
  9. Asus Transformer Pad TF103C Speakers Replacement: paso 9, imagen 1 de 2 Asus Transformer Pad TF103C Speakers Replacement: paso 9, imagen 2 de 2
    • Remove the two speakers from the frame.
Conclusión
Tyler Ellis
Miembro Desde 10/28/15
668 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 3-6, Shastany Fall 2015 Miembro de UMass Dartmouth, Team 3-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G6
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 443
