Saltar al contenido principal
Asus Transformer Pad Infinity Battery Replacement
Qué necesitas
  1. Asus Transformer Pad Infinity Battery Replacement, Battery: paso 1, imagen 1 de 3 Asus Transformer Pad Infinity Battery Replacement, Battery: paso 1, imagen 2 de 3 Asus Transformer Pad Infinity Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  2. Asus Transformer Pad Infinity Battery Replacement: paso 2, imagen 1 de 1
    • Disconnect the battery from the big motherboard.
  3. Asus Transformer Pad Infinity Battery Replacement: paso 3, imagen 1 de 1
    • Unscrew all eight screws connecting the battery to the case.
    • Remove the battery.
  4. Asus Transformer Pad Infinity Battery Replacement: paso 4, imagen 1 de 1
    • Place the new battery in the same spot as the old battery.
    • Screw the eight screws back in place to connect the new battery to the case.
Conclusión
Allison Poh
Miembro Desde 10/20/15
549 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 19
Todo El Tiempo: 2,921
