Saltar al contenido principal
Asus Eee PC 900 RAM Replacement
Qué necesitas
  1. Asus Eee PC 900 RAM Replacement, Battery: paso 1, imagen 1 de 3 Asus Eee PC 900 RAM Replacement, Battery: paso 1, imagen 2 de 3 Asus Eee PC 900 RAM Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 RAM Replacement: paso 2, imagen 1 de 1
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 RAM Replacement, RAM: paso 3, imagen 1 de 2 Asus Eee PC 900 RAM Replacement, RAM: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the sticker from the RAM compartment using a pair of tweezers.
  4. Asus Eee PC 900 RAM Replacement: paso 4, imagen 1 de 2 Asus Eee PC 900 RAM Replacement: paso 4, imagen 2 de 2
    • Remove the two 4.8 mm screws using a Phillips #0 screwdriver.
  5. Asus Eee PC 900 RAM Replacement: paso 5, imagen 1 de 1
    • Open up the cover from the bottom by carefully prying it open with a plastic opening tool.
    • Be gentle when prying open the cover in order to not damage it.
  6. Asus Eee PC 900 RAM Replacement: paso 6, imagen 1 de 1
    • Remove the back cover by pulling up on the side that had the screws.
  7. Asus Eee PC 900 RAM Replacement: paso 7, imagen 1 de 2 Asus Eee PC 900 RAM Replacement: paso 7, imagen 2 de 2
    • Use a spudger to push the top of the pin on the right towards the right (so it isn't holding the RAM chip).
    • Do the same for the left pin. Push the top of the pin towards the left.
    • The RAM should pop up.
  8. Asus Eee PC 900 RAM Replacement: paso 8, imagen 1 de 1
    • Remove the RAM chip by grabbing the top of the chip and pulling it upwards.
    • Be gentle when removing the RAM because it is a very delicate part and you do not want to break any of the pins in the computer.
Conclusión
5 personas más completaron esta guía.
Brian Carreon
Miembro Desde 01/25/12
288 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-27, Amido Winter 2012 Miembro de Cal Poly, Team 3-27, Amido Winter 2012
CPSU-AMIDO-W12S3G27
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 39
Todo El Tiempo: 8,816
