Saltar al contenido principal
Asus Eee PC 1005PEB Wifi Card Replacement
Qué necesitas
  1. Asus Eee PC 1005PEB Wifi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Start by placing the laptop upside-down on a flat surface.
    • Find the two clips on the back portion of the laptop.
  2. Asus Eee PC 1005PEB Wifi Card Replacement: paso 2, imagen 1 de 1
    • Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • This clip will hold itself, so after you move it to the unlock position you can remove your finger.
  3. Asus Eee PC 1005PEB Wifi Card Replacement: paso 3, imagen 1 de 2 Asus Eee PC 1005PEB Wifi Card Replacement: paso 3, imagen 2 de 2
    • Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position.
    • While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • When the pins on the battery that reach towards the laptop are away from the laptop, you can release the "2" clip.
  4. Asus Eee PC 1005PEB Wifi Card Replacement: paso 4, imagen 1 de 1
    • Using both hands, pull the battery horizontally away from the laptop.
  5. Asus Eee PC 1005PEB Wifi Card Replacement, Keyboard: paso 5, imagen 1 de 1
    • Face the laptop so the 4 silver "clips" along the middle of the battery cartridge are in front of you.
  6. Asus Eee PC 1005PEB Wifi Card Replacement: paso 6, imagen 1 de 3 Asus Eee PC 1005PEB Wifi Card Replacement: paso 6, imagen 2 de 3 Asus Eee PC 1005PEB Wifi Card Replacement: paso 6, imagen 3 de 3
    • Using the wide opening tool, unhook each clip from its original position by pulling the clip towards you.
    • Repeat for all four of the clips.
  7. Asus Eee PC 1005PEB Wifi Card Replacement: paso 7, imagen 1 de 1
    • Turn the laptop right side up and lift the lid.
    • Insert the flat end of the spudger into the small gap between the top of the keyboard and the plastic of the laptop.
    • Using the spudger as leverage, lift the keyboard up from the rest of the laptop.
    • Run the spudger across the seam until the entire top edge is exposed. The two sides of the keyboard should also pop up in this process.
  8. Asus Eee PC 1005PEB Wifi Card Replacement: paso 8, imagen 1 de 1
    • The keyboard should now lift from the base of the laptop.
    • Do not lift the keyboard up to quickly or too hard, since a ribbon cable is still attached to the keyboard and doing so could break it.
  9. Asus Eee PC 1005PEB Wifi Card Replacement: paso 9, imagen 1 de 3 Asus Eee PC 1005PEB Wifi Card Replacement: paso 9, imagen 2 de 3 Asus Eee PC 1005PEB Wifi Card Replacement: paso 9, imagen 3 de 3
    • Using the pointed end of the spudger tool, disconnect the ribbon cable that extends from the bottom of the keyboard to the computer by pushing on the connections of the cable.
    • Once the ribbon cable is disconnected, the keyboard can be fully removed by lifting it away from the laptop.
  10. Asus Eee PC 1005PEB Wifi Card Replacement, Wifi Card: paso 10, imagen 1 de 2 Asus Eee PC 1005PEB Wifi Card Replacement, Wifi Card: paso 10, imagen 2 de 2
    • Turn laptop upside down.
    • Find and unscrew the 5.5 mm Phillips #1 screw on the ram cover.
    • The screw and ram cover are connected and will not separate.
  11. Asus Eee PC 1005PEB Wifi Card Replacement: paso 11, imagen 1 de 2 Asus Eee PC 1005PEB Wifi Card Replacement: paso 11, imagen 2 de 2
    • Carefully remove the cover by lifting it with your fingers.
    • Make sure that you do not pull the cover too hard because there are plastic pins that hold the cover on.
  12. Asus Eee PC 1005PEB Wifi Card Replacement: paso 12, imagen 1 de 2 Asus Eee PC 1005PEB Wifi Card Replacement: paso 12, imagen 2 de 2
    • Locate and remove the silver 6.65 mm Phillips #1 screw in the bottom right corner of the opening.
  13. Asus Eee PC 1005PEB Wifi Card Replacement: paso 13, imagen 1 de 1
    • Remove the four 6 mm screws with the Phillips #1 screwdriver.
  14. Asus Eee PC 1005PEB Wifi Card Replacement: paso 14, imagen 1 de 3 Asus Eee PC 1005PEB Wifi Card Replacement: paso 14, imagen 2 de 3 Asus Eee PC 1005PEB Wifi Card Replacement: paso 14, imagen 3 de 3
    • Release the 3 black clips by pushing them in with the pointed end of the spludger.
  15. Asus Eee PC 1005PEB Wifi Card Replacement: paso 15, imagen 1 de 1
    • This step will void the warranty
    • Remove the all five 5.5 mm Phillips #1 screws.
  16. Asus Eee PC 1005PEB Wifi Card Replacement: paso 16, imagen 1 de 1
    • Remove the ribbon cable that is connected to the circuit board with the pointed end of the spudger.
  17. Asus Eee PC 1005PEB Wifi Card Replacement: paso 17, imagen 1 de 3 Asus Eee PC 1005PEB Wifi Card Replacement: paso 17, imagen 2 de 3 Asus Eee PC 1005PEB Wifi Card Replacement: paso 17, imagen 3 de 3
    • Pry up the plastic frame at the top corners.
    • Use the wide end of spudger and slide it between the bottom case and the plastic red to release it.
    • The red plastic frame and the silver piece of metal are connected and will come off together.
  18. Asus Eee PC 1005PEB Wifi Card Replacement: paso 18, imagen 1 de 2 Asus Eee PC 1005PEB Wifi Card Replacement: paso 18, imagen 2 de 2
    • Fold back the ribbon cable away from you.
    • Remove the 3.6 mm Phillip #1 screw.
  19. Asus Eee PC 1005PEB Wifi Card Replacement: paso 19, imagen 1 de 1
    • Fold the ribbon cable the opposite way and lift up the wifi card.
  20. Asus Eee PC 1005PEB Wifi Card Replacement: paso 20, imagen 1 de 2 Asus Eee PC 1005PEB Wifi Card Replacement: paso 20, imagen 2 de 2
    • Remove the Wi-Fi card by pulling the card away from where it was plugged in.
    • Don't pull the wifi card out too fast because the antenna is still attached and doing so could damage the antenna or connector.
  21. Asus Eee PC 1005PEB Wifi Card Replacement: paso 21, imagen 1 de 2 Asus Eee PC 1005PEB Wifi Card Replacement: paso 21, imagen 2 de 2
    • Pull the antenna away from the wifi card to remove it.
Conclusión
4 personas más completaron esta guía.
Aaron Arenas
Miembro Desde 04/20/14
751 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-32, Maness Spring 2014 Miembro de Cal Poly, Team 13-32, Maness Spring 2014
CPSU-MANESS-S14S13G32
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 1,697
