Introducción
Replacing the inverter, a common cause for what looks to be a loss of backlight.
Partes
No se requieren partes.
Lay the display facing down with the stand away from you. Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  • Lay the display facing down with the stand away from you.
  • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
Agregar Comentario
Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
Agregar Comentario
Rotate the display so the legs of the display are now facing you
  • Rotate the display so the legs of the display are now facing you
  • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
Agregar Comentario
Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
Agregar Comentario
The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
Agregar Comentario
Now locate and remove the lone screw holding the EMI shield to the display
  • Now locate and remove the lone screw holding the EMI shield to the display
Agregar Comentario
Now that the screw has been removed, slide the panel towards your body and lift it out. You may need to remove the clear USB port cover to remove the metal EMI shield.
  • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
Agregar Comentario
Remove these three screws holding the board to the display
  • Remove these three screws holding the board to the display
Agregar Comentario
Remove these five cables connection the inverter to the backlights and logic board.
  • Remove these five cables connection the inverter to the backlights and logic board.
    • Taking note where they connect to for reassembly
Agregar Comentario
Remove and replace the inverter
  • Remove and replace the inverter
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Andrew Tsao
Miembro Desde 19/01/10
159 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-20, Maness Winter 2010 Miembro de Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 5
Todo El Tiempo: 5,952
