Qué necesitas
Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
Lift the heat shield up and toward you.
2 personas más completaron esta guía.
