Partes
No se requieren partes.
Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
  • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
  • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
Agregar Comentario
Pull the keyboard ribbon vertically from the logic board to release connection.
  • Pull the keyboard ribbon vertically from the logic board to release connection.
  • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
  • Remove battery and CD/DVD drives before proceeding any further.
Agregar Comentario
Your computer should look approximately like this.
  • Your computer should look approximately like this.
Agregar Comentario
Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
  • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
  • Lift the heat shield up and toward you.
Agregar Comentario
Pull the PRAM battery cable vertically upward to disconnect it.
  • Pull the PRAM battery cable vertically upward to disconnect it.
  • Remove the battery by pulling up and to the left.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the two T8 Torx screws that attach the heat sink to the processor.
  • Remove the two T8 Torx screws that attach the heat sink to the processor.
  • Remove the long silver Phillips #1 screw from the heat sink.
Agregar Comentario
Lift up the heat sink unit from the left side and remove.
  • Lift up the heat sink unit from the left side and remove.
Agregar Comentario
Lift the processor on the right side and pull directly up.
  • Lift the processor on the right side and pull directly up.
  • The RAM chips should be in the slots on the processor.
Agregar Comentario
After removing the RAM, your laptop should now look like this.
  • After removing the RAM, your laptop should now look like this.
Agregar Comentario
Locate the orange tab, which should be just left of the hard-drive.
  • Locate the orange tab, which should be just left of the hard-drive.
  • You must disconnect this orange tab from the logic board to enable the next step.
  • It is better to do this by grabbing the plastic connection point, not the relatively flexible cable.
Agregar Comentario
Grab the plastic strip shown here and gently remove, pulling up and left.
  • Grab the plastic strip shown here and gently remove, pulling up and left.
  • Pull left to avoid the hard drive catching the casing.
Agregar Comentario
Once you have removed the hard-drive, your laptop should like this.
  • Once you have removed the hard-drive, your laptop should like this.
Agregar Comentario
Each of the Torx screws will need to be removed. They are located at each corner.
  • Each of the Torx screws will need to be removed. They are located at each corner.
Agregar Comentario
Applying even pressure during this step is key. You must be careful not to damage the hard-drive beyond repair.
  • Applying even pressure during this step is key. You must be careful not to damage the hard-drive beyond repair.
  • The pins are very sensitive.
  • Pull the connector cable from the hard-drive with even pressure the entire time.
Agregar Comentario
Conclusión
Byron Hoefer
Miembro Desde 18/04/11
70 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-2, Regan Spring 2011 Miembro de Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 1,661
