Introducción
If all other troubleshooting options fail, you may need to replace the logic board.
Partes
No se requieren partes.
First start by peeling off the outer rubbery covering on the bottom of the device.
  • First start by peeling off the outer rubbery covering on the bottom of the device.
  • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
Agregar Comentario
After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
  • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
Agregar Comentario
After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
Agregar Comentario
The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell. It should make a click when it comes apart. It should make a click when it comes apart.
  • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
  • It should make a click when it comes apart.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the outer casing.
  • Remove the outer casing.
  • The exposed logic board should look like this.
Remove the 3 connectors from the logic board to the antennas before removing the logic board from the metal surround.
Dan McGoldrick - Contestar
Take the device out of the casing and orient it so that you can see the WiFi card.
  • Take the device out of the casing and orient it so that you can see the WiFi card.
Agregar Comentario
Wires come from the three antennas and connect on the outer edge of the WiFi card.
  • Wires come from the three antennas and connect on the outer edge of the WiFi card.
  • Carefully pull up on the end of one of the wires to disconnect it from the motherboard.
  • Do this for the remaining two wires.
Agregar Comentario
There are two clips attached to the upper and lower ends of the WiFi card
  • There are two clips attached to the upper and lower ends of the WiFi card
  • CAUTION: For the following step, do not pull the clip after you have detached it. The clip is fragile and too much force may cause the clip to break.
  • Grab the end of one of the clips and pull away from the WiFi card. This should make the clip visibly detached from the WiFi card.
  • Do the same for the other clip.
Agregar Comentario
Grasp the upper and lower ends of the WiFi card. Carefully pull the WiFi card to the right.
  • Grasp the upper and lower ends of the WiFi card.
  • Carefully pull the WiFi card to the right.
  • CAUTION: Do not pull UP (towards yourself) on the WiFi card when removing. The card is on a track that only allows it to move left and right. Forcing the card to move in other directions may result in breaking the track.
  • Completely remove the WiFi card.
Agregar Comentario
Remove the metal casing by gently prying the logic board away with you hands.
  • Remove the metal casing by gently prying the logic board away with you hands.
  • This should be pretty easy, you already removed the screws holding these pieces together.
Agregar Comentario
Remove the battery by gently "shoving" it out with the plastic tool. Remove the battery by gently "shoving" it out with the plastic tool. Remove the battery by gently "shoving" it out with the plastic tool.
  • Remove the battery by gently "shoving" it out with the plastic tool.
Agregar Comentario
This is the "naked" logic board. You can order a new one and replace it by following the above steps in reverse order.
  • This is the "naked" logic board. You can order a new one and replace it by following the above steps in reverse order.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Brandon
Miembro Desde 02/04/12
306 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-2, Forte Spring 2012 Miembro de Cal Poly, Team 5-2, Forte Spring 2012
CPSU-FORTE-S12S5G2
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 10
Últimos 30 Días: 31
Todo El Tiempo: 7,051
