Saltar al contenido principal
Amazon Fire HD 8 Screen Replacement
Qué necesitas
  1. Amazon Fire HD 8 Screen Replacement, Screen: paso 1, imagen 1 de 2 Amazon Fire HD 8 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Screen Replacement: paso 2, imagen 1 de 1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Screen Replacement: paso 3, imagen 1 de 3 Amazon Fire HD 8 Screen Replacement: paso 3, imagen 2 de 3 Amazon Fire HD 8 Screen Replacement: paso 3, imagen 3 de 3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Screen Replacement: paso 4, imagen 1 de 3 Amazon Fire HD 8 Screen Replacement: paso 4, imagen 2 de 3 Amazon Fire HD 8 Screen Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
Conclusión
27 personas más completaron esta guía.
Dan Shimkus
Miembro Desde 02/24/16
1,184 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-3, Leahy Spring 2016 Miembro de USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
4 Miembros
17 Guías creadas
18 comentarios
Very nice, but even Amazon is not marketing the replacement screens.
Wendy Huntington Parker Fages - Contestar
True, but if you happen to find another dysfunctional Fire ( with an intact screen) you can always harvest the display from that one and put it on your functioning unit. Long shot. But that's why this repair guide is still helpful even though parts aren't readily available.
Kelsea Weber -
Fingers crossed Amazon offers more parts in the future! :)
Kelsea Weber -
I ordered one from Amazon yesterday. Supposed to be 2 day shipping. Certainly not the $12 cheepy from China, but hopefully it will actually be shipped and delivered to my house. Any item Ive ever ordered that ended up being shipped directly from China has never found its way to my house and ends up costing about a months delay in the fixing of whatever device i have taken on the responsibility of to try & repair for someone.
Worth the $29 i’m paying at Amazon
Kitty Morgan -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 116
Ultimos 30 días: 448
Todo El Tiempo: 68,407
