Saltar al contenido principal
Alternative Opening Procedure
Qué necesitas
  1. Alternative Opening Procedure, Alternative Opening Procedure: paso 1, imagen 1 de 1
    • Instead of a putty knife a dozen or more 1-1/2" pins are required.
  2. Alternative Opening Procedure: paso 2, imagen 1 de 2 Alternative Opening Procedure: paso 2, imagen 2 de 2
    • With the computer upside down identify the apertures where the catches are located along either side and also at the front.
    • Insert the pins from the adjacent apertures between the wall and each catch. Be very careful to keep the pins against the case wall. This is more obvious from the second photo with the case removed.
  3. Alternative Opening Procedure: paso 3, imagen 1 de 1
    • Lift the case off from the back first.
    • Remove the pins from the main assembly.
Conclusión
Re-assembly does not require the pins. Place the case over the computer and press down evenly on the sides, not the middle. Ensure the back panel is correctly aligned before finally pushing home the catches.
16 personas más completaron esta guía.
Donald Todd
Miembro Desde 09/22/10
528 Reputación
1 Guía escrita
Un comentario
I've recently acquired a G4 Mini 1.33 "Silent Upgrade" on eBay and plan on opening up using your guide :) Thanks so very, VERY much!
Tyler Regas - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 15,029
