Saltar al contenido principal
Alienware 15 R2 Battery Replacement
Qué necesitas
  1. Alienware 15 R2 Battery Replacement, RAM: paso 1, imagen 1 de 3 Alienware 15 R2 Battery Replacement, RAM: paso 1, imagen 2 de 3 Alienware 15 R2 Battery Replacement, RAM: paso 1, imagen 3 de 3
    • Place laptop upside down with the hinge facing you, then remove the two 9mm Phillips #0 screws located in the bottom left and right of the of the rear panel.
    • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
  2. Alienware 15 R2 Battery Replacement: paso 2, imagen 1 de 2 Alienware 15 R2 Battery Replacement: paso 2, imagen 2 de 2
    • Use the iFixit opening tool to disconnect the battery cable. Put the iFixit tool underneath the cable and then pull it to remove.
  3. Alienware 15 R2 Battery Replacement: paso 3, imagen 1 de 2 Alienware 15 R2 Battery Replacement: paso 3, imagen 2 de 2
    • Find the RAM located near the edge of the computer closest to you. Locate the small latches on either side of the RAM stick and push in the two latches to release. Gently grasp the RAM stick on either side and pull straight out. Repeat for the second RAM stick.
  4. Alienware 15 R2 Battery Replacement, Battery: paso 4, imagen 1 de 2 Alienware 15 R2 Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Using a Phillips #0 remove the small 1X 3mm screw behind where the RAM used to be.
  5. Alienware 15 R2 Battery Replacement: paso 5, imagen 1 de 1
    • Remove all screws from the back casing. (4X 18mm, 4X 10mm, 4X 6mm)
    • Press your finger in the hole next to the hard drive to lift the key board.
  6. Alienware 15 R2 Battery Replacement: paso 6, imagen 1 de 1
    • Disconnect and move aside the left and right wires.
  7. Alienware 15 R2 Battery Replacement: paso 7, imagen 1 de 2 Alienware 15 R2 Battery Replacement: paso 7, imagen 2 de 2
    • Using a Phillips #0 remove the screws holding the battery in. (3X 6mm)
    • You may also remove the ribbon cables on the bottom of the laptop to gain more room to work. (This is not required)
  8. Alienware 15 R2 Battery Replacement: paso 8, imagen 1 de 1
    • Remove the red, white, blue, and black colored wires connected to the motherboard.
  9. Alienware 15 R2 Battery Replacement: paso 9, imagen 1 de 1
    • Lift the battery from the front edge and remove.
Conclusión
2 personas más completaron esta guía.
Un comentario
Honestly made an account to comment on this repair guide, this is extremely incomplete. I’d go as far as saying you’re likely to damage the product by relying solely on this guide, I would turn to a breakdown on YouTube instead. I’m not sure if this is listed under the correct product.
mdumtshali - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 35
Ultimos 30 días: 172
Todo El Tiempo: 9,764
