Introducción
The image sensor is the component of the device responsible for sensing the light through the lens and converting it into an electrical signal. The sensor captures a new image 30 times per second in order to create a video. The sensor is a very fragile and sensitive component. Take caution when handling the new image sensor to be installed in the device. Use this guide to replace the image sensor.
Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
  • Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
  • Slide the battery compartment cover down off of the camera body.
Agregar Comentario
Pry up the battery from the bottom using a finger and remove the batter from the case.
  • Pry up the battery from the bottom using a finger and remove the batter from the case.
Agregar Comentario
Remove the lanyard by pulling the grey lace through the black string loop.
  • Remove the lanyard by pulling the grey lace through the black string loop.
  • Pull black string loop through the silver bracket.
Agregar Comentario
Use a plastic opening tool to pry off the black control cover.
  • Use a plastic opening tool to pry off the black control cover.
  • The face plates are glued, so use force to pry the face plates from the camera body.
Agregar Comentario
Use a plastic opening tool to pry off the ridged back face plate and the black button.
  • Use a plastic opening tool to pry off the ridged back face plate and the black button.
  • The button is loose and should come off with little or no effort.
Agregar Comentario
Use a plastic opening tool to pry off the silver face plate.
  • Use a plastic opening tool to pry off the silver face plate.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Open the USB cover to expose the small machine screw. Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body). These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
  • Open the USB cover to expose the small machine screw.
  • Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body).
  • These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
Agregar Comentario
Pull off the side control panel.
  • Pull off the side control panel.
Agregar Comentario
Flip open the screen by pulling the loose end of the screen away from the case. Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
  • Flip open the screen by pulling the loose end of the screen away from the case.
  • Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
  • Use the #00 Phillips Screwdriver to remove both screws.
Agregar Comentario
Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder. Use tweezers to remove the silver plastic strap holder.
  • Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder.
  • Use tweezers to remove the silver plastic strap holder.
  • Use a plastic opening tool to pry off the lens protector.
Agregar Comentario
Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver. Lift off the lens protector housing. Pull apart the two halves of the camera body.
  • Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver.
  • Lift off the lens protector housing.
  • Pull apart the two halves of the camera body.
  • Do not pull the two halves apart too far because the wires may detach.
Agregar Comentario
Unscrew both black machine screws holding the lens in place with the #00 Phillips screwdriver.
  • Unscrew both black machine screws holding the lens in place with the #00 Phillips screwdriver.
Agregar Comentario
Carefully remove the compressed springs underneath each of the two screws that were removed in the previous step.
  • Carefully remove the compressed springs underneath each of the two screws that were removed in the previous step.
  • Be careful not to lose the springs. The springs are in compression and will launch from the camera if not held onto.
Agregar Comentario
Lift off the lens.
  • Lift off the lens.
Agregar Comentario
Use the #00 Phillips Screwdriver to unscrew the 3 circuit board screws. Slightly separate circuit board from plastic case by lifting the circuit board  straight out.
  • Use the #00 Phillips Screwdriver to unscrew the 3 circuit board screws.
  • Slightly separate circuit board from plastic case by lifting the circuit board straight out.
Agregar Comentario
Unplug the image sensor from the circuit board. Pull the image sensor straight out to avoid damage to the pin connectors.
  • Unplug the image sensor from the circuit board.
  • Pull the image sensor straight out to avoid damage to the pin connectors.
Agregar Comentario
Conclusión
Zachary Yun
Miembro Desde 03/04/12
7 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-5, Forte Spring 2012 Miembro de Cal Poly, Team 5-5, Forte Spring 2012
CPSU-FORTE-S12S5G5
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 632
