Introducción
If your calculator does not appear to light up, it could be that the contrast is at a low setting. Use this guide to aid you in adjusting the contrast.
Remove the front protective cover by sliding it off of the calculator. Press the "ON" button to turn on the calculator.
  • Remove the front protective cover by sliding it off of the calculator.
  • Press the "ON" button to turn on the calculator.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Press the "2ND" button at the top left portion of the keypad. An arrow pointing up will appear at the top left corner of the screen. Press and hold the "UP" arrow until you have increased the contrast to a level that is easily visible for yourself. A common level to set the contrast is 5. To decrease the contrast, press the "2ND" button, then press and hold the "DOWN" arrow.
  • Press the "2ND" button at the top left portion of the keypad. An arrow pointing up will appear at the top left corner of the screen.
  • Press and hold the "UP" arrow until you have increased the contrast to a level that is easily visible for yourself. A common level to set the contrast is 5.
  • To decrease the contrast, press the "2ND" button, then press and hold the "DOWN" arrow.
Agregar Comentario
Conclusión
Now you should have the image contrast set to your preferences.
Una persona más ha completado esta guía.
Alan Wong
Miembro Desde 26/09/12
63 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-52, Forte Fall 2012 Miembro de Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 13
Últimos 30 Días: 47
Todo El Tiempo: 3,456
