Saltar al contenido principal
Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board Replacement
Qué necesitas
  1. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: paso 1, imagen 1 de 2 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: paso 1, imagen 2 de 2
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: paso 2, imagen 1 de 1
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: paso 3, imagen 1 de 3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: paso 3, imagen 2 de 3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: paso 3, imagen 3 de 3
    • Identify the port that is connected to the speaker.
    • Using tweezers, separate the cable from the port.
  4. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: paso 4, imagen 1 de 2 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: paso 4, imagen 2 de 2
    • Find and remove the blue tape from the circuit board.
  5. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: paso 5, imagen 1 de 3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: paso 5, imagen 2 de 3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: paso 5, imagen 3 de 3
    • Remove the black tape from the port.
  6. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: paso 6, imagen 1 de 3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: paso 6, imagen 2 de 3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: paso 6, imagen 3 de 3
    • Identify the two Phillips screws.
    • Remove the two screws holding down the board with a J1 Phillips screwdriver.
    • Gently lift the board from the Chromebook.
Conclusión
Una persona más ha completado esta guía.
2 comentarios
Any ideas about where to purchase this part? I am almost certain that it is the problem with my sound. Also, I can get to it no problem, but I am struggling finding a replacement part.
littlemas2 - Contestar
I have looked on numerous pages on google, both with the part number and with the Chromebook model number and have yet to be able to find a supplier.
littlemas2 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 652
