Saltar al contenido principal
Acer Chromebook CB3-111-C670 Keyboard Key Replacement
Qué necesitas
  1. Acer Chromebook CB3-111-C670 Keyboard Key Replacement, Keyboard Key: paso 1, imagen 1 de 1
    • Remove broken key(s) using the flat end of spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular spudger and tweezer should be used whenever possible.
    • When reinstalling the key, no spudger is needed. Just pop it into place with fingers.
  2. Acer Chromebook CB3-111-C670 Keyboard Key Replacement: paso 2, imagen 1 de 2 Acer Chromebook CB3-111-C670 Keyboard Key Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using the flat end of the spudger, very carefully lift up the corners of the cradle.
    • With the help of tweezers (needle nose works best), pull the hooks of the cradle out.
    • For re-installation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Conclusión
4 personas más completaron esta guía.
Tony
Miembro Desde 01/20/16
459 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 10-5, Remmell Spring 2016 Miembro de USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Miembros
8 Guías creadas
Un comentario
no help i need help putting it on with out that
Simon Kuhn - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 98
Todo El Tiempo: 7,276
