Saltar al contenido principal
Acer Chromebook C740 LCD Screen Replacement
Qué necesitas
  1. Acer Chromebook C740 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 LCD Screen Replacement: paso 2, imagen 1 de 2 Acer Chromebook C740 LCD Screen Replacement: paso 2, imagen 2 de 2
    • With the Chromebook open and face up, pry the black screen frame with your fingers.
    • Move slowly around the display to evenly remove it.
    • Clicking sounds indicate the panel is seperating from the overall display.
  3. Acer Chromebook C740 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Once the frame is separated from the display, angle the display assembly back .
    • Lift up the portions of the frame covering the front two hinges with the spudger.
  4. Acer Chromebook C740 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Remove the frame from the screen assembly by pulling the frame towards you.
    • Some adjustment of the display assembly may be needed so that the frame is not stuck near the hinges.
  5. Acer Chromebook C740 LCD Screen Replacement: paso 5, imagen 1 de 2 Acer Chromebook C740 LCD Screen Replacement: paso 5, imagen 2 de 2
    • Remove the six 3.35mm screws with a Phillips #0 Screwdriver.
  6. Acer Chromebook C740 LCD Screen Replacement: paso 6, imagen 1 de 3 Acer Chromebook C740 LCD Screen Replacement: paso 6, imagen 2 de 3 Acer Chromebook C740 LCD Screen Replacement: paso 6, imagen 3 de 3
    • Place the LCD screen face down on the keyboard.
    • Remove the tape holding the black connector in place.
    • Unplug the connector with your hands.
Conclusión
7 personas más completaron esta guía.
Grace Bassett
Miembro Desde 04/26/17
217 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S22-G2, Livingston Spring 2017 Miembro de Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Miembros
12 Guías creadas
Un comentario
You actually don’t need to unscrew the middle screws, and you don’t need to buy a new bezel.
Keith Hudson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 24
Todo El Tiempo: 3,317
