Saltar al contenido principal
Acer Chromebook C720-2420 Battery Replacement
Qué necesitas
  1. Acer Chromebook C720-2420 Battery Replacement, Back Cover Replacement: paso 1, imagen 1 de 2 Acer Chromebook C720-2420 Battery Replacement, Back Cover Replacement: paso 1, imagen 2 de 2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer Chromebook C720-2420 Battery Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer Chromebook C720-2420 Battery Replacement, Battery: paso 3, imagen 1 de 2 Acer Chromebook C720-2420 Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer Chromebook C720-2420 Battery Replacement: paso 4, imagen 1 de 2 Acer Chromebook C720-2420 Battery Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer Chromebook C720-2420 Battery Replacement: paso 5, imagen 1 de 1
    • Remove the battery.
Conclusión
Equipo
USF Tampa, Team S15-G4, Boczar Spring 2018 Miembro de USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 555
