Saltar al contenido principal
Acer Aspire V5-552PG-X469 Battery Replacement
Qué necesitas
  1. Acer Aspire V5-552PG-X469 Battery Replacement, Back Case: paso 1, imagen 1 de 1
    • Remove the storage tray on the left edge of the device.
  2. Acer Aspire V5-552PG-X469 Battery Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove seventeen 7mm screws from the lower case.
  3. Acer Aspire V5-552PG-X469 Battery Replacement: paso 3, imagen 1 de 1
    • Lift up the back case to remove it.
  4. Acer Aspire V5-552PG-X469 Battery Replacement, Battery: paso 4, imagen 1 de 2 Acer Aspire V5-552PG-X469 Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Pull the battery connector away from the hard drive to disconnect it from its socket.
  5. Acer Aspire V5-552PG-X469 Battery Replacement: paso 5, imagen 1 de 3 Acer Aspire V5-552PG-X469 Battery Replacement: paso 5, imagen 2 de 3 Acer Aspire V5-552PG-X469 Battery Replacement: paso 5, imagen 3 de 3
    • Pull the white connector toward the battery to disconnect it.
    • Pull the black tape-wrapped connector toward the battery to disconnect it.
  6. Acer Aspire V5-552PG-X469 Battery Replacement: paso 6, imagen 1 de 2 Acer Aspire V5-552PG-X469 Battery Replacement: paso 6, imagen 2 de 2
    • Remove the PH #0 screw from the center of the battery.
  7. Acer Aspire V5-552PG-X469 Battery Replacement: paso 7, imagen 1 de 2 Acer Aspire V5-552PG-X469 Battery Replacement: paso 7, imagen 2 de 2
    • Lift up the battery to remove it.
    • Be careful not to bend the battery while lifting it out, as this may cause a fire hazard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 12
Todo El Tiempo: 1,250
