Saltar al contenido principal
Acer Aspire R7-572-6423 Battery Replacement
Qué necesitas
  1. Acer Aspire R7-572-6423 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Acer Aspire R7-572-6423 Battery Replacement: paso 2, imagen 1 de 2 Acer Aspire R7-572-6423 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the top and middle rubber feet under the laptop to reveal hidden screws.
  3. Acer Aspire R7-572-6423 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the five 6 mm T9 screws.
    • Remove the eight 10 mm T9 screws.
  4. Acer Aspire R7-572-6423 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the back cover.
  5. Acer Aspire R7-572-6423 Battery Replacement: paso 5, imagen 1 de 1
    • Unplug the ribbon cable connecting the battery to the motherboard.
    • Be careful around the motherboard, as it is easily damaged.
  6. Acer Aspire R7-572-6423 Battery Replacement: paso 6, imagen 1 de 1
    • Remove the three 4 mm Phillips #1 screws securing the battery.
  7. Acer Aspire R7-572-6423 Battery Replacement: paso 7, imagen 1 de 2 Acer Aspire R7-572-6423 Battery Replacement: paso 7, imagen 2 de 2
    • Pull open the clips on either side of the battery to free it from the case.
    • Remove the battery from the computer.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 23
Todo El Tiempo: 1,516
