Introducción
This guide will walk you through how to replace the Acer Aspire One ZG5 speakers. The speakers will need to be replaced if you find your computer making no noise.
Speakers are used in computers to generate sound to create audio output for the listeners.
Please power off your device and remove the battery before performing this repair. This guide requires moderate skill.
Qué necesitas
Turn the netbook upside down with the battery at the top, facing away from you.
Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
Turn the netbook over and open the display so that the keyboard is facing you.
Close the display and turn the ZG5 over so that the battery compartment faces away from you.
Disconnect the two antenna cables from the right side of the wireless card.
3 personas más completaron esta guía.
