Introducción
Once the motherboard is out, it is relatively straight forward to get to the fan.
Turn the netbook upside down with the battery at the top, away from you.
  • Turn the netbook upside down with the battery at the top, away from you.
Agregar Comentario
Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
Agregar Comentario
Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
Agregar Comentario
Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
  • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
Agregar Comentario
Lift up the panel and remove it from the case.
  • Lift up the panel and remove it from the case.
Agregar Comentario
Disconnect the two antenna cables from the left side of the wireless card.
  • Disconnect the two antenna cables from the left side of the wireless card.
Agregar Comentario
Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
Agregar Comentario
Gently lift up the left side of the wireless card and slide the card out of its socket.
  • Gently lift up the left side of the wireless card and slide the card out of its socket.
mi lap NO tiene wireless card
gustavo cordova - Contestar
Turn the netbook over and open the display so that the keyboard is facing you.
  • Turn the netbook over and open the display so that the keyboard is facing you.
Agregar Comentario
There are three tabs located on the top of the keyboard. Start with the spudger pointing towards the display and pry up to push each tab off the keyboard. As you move to the next tab, ensure the previous tab doesn't reset itself.
  • There are three tabs located on the top of the keyboard.
  • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
  • As you move to the next tab, ensure the previous tab doesn't reset itself.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side. There is a short ribbon cable connecting the keyboard to the netbook.
  • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
  • There is a short ribbon cable connecting the keyboard to the netbook.
Agregar Comentario
Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable. Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
  • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
Agregar Comentario
Close the display and turn the ZG5 over so that the battery compartment faces away from you.
  • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
Agregar Comentario
Remove three 5.8 mm Phillips #0 screws from the bottom of the case Remove three 3.9 mm  Phillips #1 screws  from the battery compartment.
  • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
  • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
  • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
Agregar Comentario
Turn the netbook back over and open the display with the keyboard cavity facing you.
  • Turn the netbook back over and open the display with the keyboard cavity facing you.
Agregar Comentario
Flip up the retaining flap on the trackpad ribbon cable ZIF connector. Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard. Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
  • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
  • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
Agregar Comentario
Remove the five black 4.7 mm Phillips #0 screws from the metal casing. Remove the single silver 4.3 mm Phillips #00 screw from the right side of  the metal casing.
  • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
  • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
Agregar Comentario
Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case. Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
  • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
  • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
  • Gently lift off the top case.
Agregar Comentario
Disconnect the two antenna cables from the right side of the wireless card.
  • Disconnect the two antenna cables from the right side of the wireless card.
Agregar Comentario
Remove the single 3.9 mm Phillips #1 screw from the wireless card.
  • Remove the single 3.9 mm Phillips #1 screw from the wireless card.
Agregar Comentario
Gently pull the wireless card to the right and slide it out of its socket.
  • Gently pull the wireless card to the right and slide it out of its socket.
Agregar Comentario
Disconnect the display cable from the top left of the motherboard.
  • Disconnect the display cable from the top left of the motherboard.
Agregar Comentario
Disconnect the speaker cable from its socket on the motherboard. Disconnect the speaker cable from its socket on the motherboard.
  • Disconnect the speaker cable from its socket on the motherboard.
Agregar Comentario
Remove three 3.9 mm Phillips #1  screws from the small  I/O board.
  • Remove three 3.9 mm Phillips #1 screws from the small I/O board.
  • Remove a single 3.9 mm Phillips #0 screw from the front of the motherboard.
    • Some laptops may instead have a single 4.7 mm Phillips #0 screw.
Agregar Comentario
Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
  • Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
Agregar Comentario
Gently lift the I/O board up from the right side of the case.
  • Gently lift the I/O board up from the right side of the case.
    • The I/O board is attached to the motherboard by a short cable.
I took apart an SSD variant. At this step, there were two screws holding the SSD down, but the SSD did not come out with the main and daughter boards. Detaching the I/O cable freed the mainboard to come out with or without the daughterboard.
unixusr - Contestar
there are 2 silver screws that need to be removed in this step your picture shows them still installed (one is located neer audio plug, the other is located neer keyboard plug) in step 27 (next step) they have been removed without mention
Scott Riley - Contestar
I have added 1 gb of memory to my ZG5 thanks to this helpful guide. Total cost, including a spudger and a new mini screwdriver, to tackle the 00 Philips, GBP 17.57
I fear I haven't put the trackpad connector back properly, but device works great with a wireless mouse. Very many thanks.
John Serocold - Contestar
Lift the entire motherboard assembly out the case.
  • Lift the entire motherboard assembly out the case.
Agregar Comentario
Disconnect the fan cable from the motherboard. Disconnect the fan cable from the motherboard.
  • Disconnect the fan cable from the motherboard.
For info:
gray wire: +5V,
black wire: ground
maroon wire: sense
Robert Gf - Contestar
Remove the three 3.9mm screws using Phillips #1 screwdriver.
  • Remove the three 3.9mm screws using Phillips #1 screwdriver.
Agregar Comentario
Lift the fan housing from the motherboard.
  • Lift the fan housing from the motherboard.
Agregar Comentario
Conclusión
8 personas más completaron esta guía.
Doug Gallatin
Miembro Desde 05/10/10
5,756 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 7-49, Amido Fall 2010 Miembro de Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Miembros
10 Guías creadas
Steps 4~8 show to remove the wireless card from its access panel outside the computer, then steps 19~21 show to remove it from the inside once the case is off.
Redundant?
I drink beer - Contestar
There are two wireless cards -- for that exact model it looks like bluetooth and 802.11n but different models may be different
nathan -
I couldn't ask for it to be any easier. Great job.
Ron Price - Contestar
The page layout is good.well done job.thanks for providing the repairing information about Acer aspire one.it is the very interesting web page.http://djnni.com
belly william - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 10
Últimos 30 Días: 36
Todo El Tiempo: 25,944
