Saltar al contenido principal
Acer Aspire 5100 Motherboard Replacement
Qué necesitas
  1. Acer Aspire 5100 Motherboard Replacement, Fan: paso 1, imagen 1 de 1
    • Flip the laptop upside-down.
    • Remove the battery as a safety precaution.
    • Remove the four screws attached to the large panel.
  2. Acer Aspire 5100 Motherboard Replacement: paso 2, imagen 1 de 1
    • Lift and remove the panel.
  3. Acer Aspire 5100 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the two screws attached to the fan.
  4. Acer Aspire 5100 Motherboard Replacement: paso 4, imagen 1 de 2 Acer Aspire 5100 Motherboard Replacement: paso 4, imagen 2 de 2
    • Lift the fan and detach the cable that connects the fan to the motherboard.
    • The fan can break easily. Be careful when removing.
    • When detaching the cable, do not pull on the cable itself. Instead, use a small spudger to detach it at the white section that connects it to the motherboard.
  5. Acer Aspire 5100 Motherboard Replacement, Keyboard: paso 5, imagen 1 de 2 Acer Aspire 5100 Motherboard Replacement, Keyboard: paso 5, imagen 2 de 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  6. Acer Aspire 5100 Motherboard Replacement: paso 6, imagen 1 de 3 Acer Aspire 5100 Motherboard Replacement: paso 6, imagen 2 de 3 Acer Aspire 5100 Motherboard Replacement: paso 6, imagen 3 de 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  7. Acer Aspire 5100 Motherboard Replacement: paso 7, imagen 1 de 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  8. Acer Aspire 5100 Motherboard Replacement, Track Pad: paso 8, imagen 1 de 1
    • Remove the nine screws from the back edges of the laptop.
  9. Acer Aspire 5100 Motherboard Replacement: paso 9, imagen 1 de 3 Acer Aspire 5100 Motherboard Replacement: paso 9, imagen 2 de 3 Acer Aspire 5100 Motherboard Replacement: paso 9, imagen 3 de 3
    • Open the lid of the laptop and locate the cover that surrounds the keyboard and track pad.
    • Use the spudger to pry open the sides of this cover.
    • DO NOT lift cover off after detaching it because the track pad is connected to the motherboard.
  10. Acer Aspire 5100 Motherboard Replacement: paso 10, imagen 1 de 2 Acer Aspire 5100 Motherboard Replacement: paso 10, imagen 2 de 2
    • Slightly lift up the cover to see the ribbon connection.
    • Release the catch by sliding the two lugs toward the ribbon, then pull the ribbon to detach it from the motherboard.
    • Lift up the cover from the laptop.
  11. Acer Aspire 5100 Motherboard Replacement: paso 11, imagen 1 de 1
    • On the cover that was removed, flip it around and locate where the back of the track pad is.
    • Remove the three screws located at the corners.
    • Lift up the bracket that you just unscrewed and remove track pad.
  12. Acer Aspire 5100 Motherboard Replacement, LCD Monitor: paso 12, imagen 1 de 1
    • Remove the two screws from each corner beneath the LCD screen.
  13. Acer Aspire 5100 Motherboard Replacement: paso 13, imagen 1 de 2 Acer Aspire 5100 Motherboard Replacement: paso 13, imagen 2 de 2
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  14. Acer Aspire 5100 Motherboard Replacement: paso 14, imagen 1 de 2 Acer Aspire 5100 Motherboard Replacement: paso 14, imagen 2 de 2
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  15. Acer Aspire 5100 Motherboard Replacement: paso 15, imagen 1 de 1
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  16. Acer Aspire 5100 Motherboard Replacement: paso 16, imagen 1 de 1
    • Lift up the monitor to detach it.
  17. Acer Aspire 5100 Motherboard Replacement, Motherboard: paso 17, imagen 1 de 1
    • Remove the 15 screws from the motherboard.
    • There is normally only one remaining screw attached to the motherboard on the bottom right beneath the tape.
    • All the other screw holes (except screws holding the base cover on) are kept empty.
  18. Acer Aspire 5100 Motherboard Replacement: paso 18, imagen 1 de 1
    • Locate the heat sink, which is the copper "L" shaped component, and unscrew the four screws that connect it to the motherboard.
  19. Acer Aspire 5100 Motherboard Replacement: paso 19, imagen 1 de 1
    • Push out the back of the casing by the VGA connector to remove the motherboard.
  20. Acer Aspire 5100 Motherboard Replacement: paso 20, imagen 1 de 2 Acer Aspire 5100 Motherboard Replacement: paso 20, imagen 2 de 2
    • Lift up and remove the motherboard from the laptop casing.
    • Remove the USB add-on card to use it with the new motherboard.
    • To remove, grab on the sides and lift upward.
Conclusión
8 personas más completaron esta guía.
Brad Rollinson
Miembro Desde 09/29/10
1,113 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 14-39, Forte Fall 2010 Miembro de Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Miembros
10 Guías creadas
6 comentarios
que tipo de motherboard puedo comprar para una laptop acer aspire 5100-3357
KALALA - Contestar
Thank you. I followed the guide as closely as possible. I am installing Windows 76 Ultimate on it again.
Thank you!
rogers518086 - Contestar
a lot of stuff missing in terms of unscrewing certain screws to get the cover off. I got stuck at step 10 because the cover was still attached by various screws.
Maybe I have a different model, but it is for sure an Acer Aspire 5100.
I also broke a lot of connection where screws thread in to, hopefully it goes back together rigidly enough.
Jamie Beurklian - Contestar
It is not neccessary for a full strip down, just to get at the CPU. Access from the main cover, remove fan and heatsink. The CPU can now be removed as in the final steps.
Richard - Contestar
You have to remove the video cable, wifi cables and LCD before you try to remove the touchpad/upper cover. You must also remove two screws from the bottom labeled 10x. In other words, you should complete steps 12 to 16 and remove the 10x screws before attempting to complete steps 9 to 11.
Nelson Mata - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 44,345
