Introducción
Replace a broken fan for an Acer Aspire 5100 laptop.
Place the laptop upside down.
  • Place the laptop upside down.
  • Although the battery is missing in this photo, it is not necessary to remove.
  • Locate the largest removable panel on the back and remove the four screws connecting it.
Agregar Comentario
Lift up and remove the panel.
  • Lift up and remove the panel.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Locate the fan and remove the two screws connecting it.
  • Locate the fan and remove the two screws connecting it.
Agregar Comentario
Lift out the fan CAREFULLY and detach the cable that connects the fan to the motherboard. When detaching the cable, do not pull on the cable itself. Instead, use a small spudger to detach it at the white section that connects it to the motherboard.
  • Lift out the fan CAREFULLY and detach the cable that connects the fan to the motherboard.
    • When detaching the cable, do not pull on the cable itself. Instead, use a small spudger to detach it at the white section that connects it to the motherboard.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Brad Rollinson
Miembro Desde 29/09/10
1,089 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 14-39, Forte Fall 2010 Miembro de Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 8
Últimos 30 Días: 27
Todo El Tiempo: 12,691
