Introducción
This guide will require you to disassemble the rear and side panels of the printer in order to access the circuit board.
Partes
No se requieren partes.
Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
  • Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
Agregar Comentario
Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2  screws on the back of the printer.
  • Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2 screws on the back of the printer.
Agregar Comentario
Gently lift the top panel while simultaneously pulling off the back panel. Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot. Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  • Gently lift the top panel while simultaneously pulling off the back panel.
  • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
Agregar Comentario
Remove the front panel by gently moving the holes on the panel from the pegs attached to the main printer body one at a time. Be sure to remove the entire front panel and not just the flap on the paper tray. Remove the front panel by gently moving the holes on the panel from the pegs attached to the main printer body one at a time. Be sure to remove the entire front panel and not just the flap on the paper tray. Remove the front panel by gently moving the holes on the panel from the pegs attached to the main printer body one at a time. Be sure to remove the entire front panel and not just the flap on the paper tray.
  • Remove the front panel by gently moving the holes on the panel from the pegs attached to the main printer body one at a time. Be sure to remove the entire front panel and not just the flap on the paper tray.
Agregar Comentario
Using a Phillips #2 screwdriver, remove the two, 1", Phillips, PH#2 screws on the front face of the printer.
  • Using a Phillips #2 screwdriver, remove the two, 1", Phillips, PH#2 screws on the front face of the printer.
Agregar Comentario
Using a plastic opening tool, gently lift one side of the top panel from its peg. Repeat the process for the other side. Lift the top panel from the front to remove it entirely.
  • Using a plastic opening tool, gently lift one side of the top panel from its peg.
  • Repeat the process for the other side.
  • Lift the top panel from the front to remove it entirely.
Agregar Comentario
Lift the right side panel up from the raised stops. Gently rotate the panel as indicated in the picture to remove the panel entirely. Gently rotate the panel as indicated in the picture to remove the panel entirely.
  • Lift the right side panel up from the raised stops.
  • Gently rotate the panel as indicated in the picture to remove the panel entirely.
Agregar Comentario
Using a Phillips #2 screwdriver, remove the four, 1", Phillips, PH#2 screws attaching the gray plate to the printer.
  • Using a Phillips #2 screwdriver, remove the four, 1", Phillips, PH#2 screws attaching the gray plate to the printer.
  • Remove the plastic cover gently by sliding it under the silver hinges on the right.
Agregar Comentario
Using a Phillips screwdriver, remove the, 1", Phillips, PH#2 screw attaching the circuit board to the printer.
  • Using a Phillips screwdriver, remove the, 1", Phillips, PH#2 screw attaching the circuit board to the printer.
Agregar Comentario
Turn over the circuit board to access main wiring. Gently unplug the wiring from the circuit board.
  • Turn over the circuit board to access main wiring.
  • Gently unplug the wiring from the circuit board.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
bbaustin
Miembro Desde 12/10/11
199 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 17-18, Regan Fall 2011 Miembro de Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 2,292
