Saltar al contenido principal
Accessing Nokia 3100b Vibrating Unit
Qué necesitas
  1. Accessing Nokia 3100b Vibrating Unit, Battery: paso 1, imagen 1 de 1
    • Make sure your phone is turned off.
  2. Accessing Nokia 3100b Vibrating Unit: paso 2, imagen 1 de 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Accessing Nokia 3100b Vibrating Unit, SIM Card: paso 3, imagen 1 de 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Accessing Nokia 3100b Vibrating Unit: paso 4, imagen 1 de 1
    • Retrieve your SIM card.
  5. Accessing Nokia 3100b Vibrating Unit, Vibrating Unit: paso 5, imagen 1 de 1
    • Separate the front cover from the base of the phone.
    • Set the front cover, as indicated, aside.
  6. Accessing Nokia 3100b Vibrating Unit: paso 6, imagen 1 de 1
    • Remove the screws indicated using a T6 Torx screwdriver.
    • Remove them in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple).
  7. Accessing Nokia 3100b Vibrating Unit: paso 7, imagen 1 de 1
    • Separate the screen assembly from the base of the phone.
    • Set the screen assembly, as indicated, aside.
  8. Accessing Nokia 3100b Vibrating Unit: paso 8, imagen 1 de 1
    • The vibrating unit can now be accessed. Note its location in the phone.
  9. Accessing Nokia 3100b Vibrating Unit: paso 9, imagen 1 de 1
    • The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
  10. Accessing Nokia 3100b Vibrating Unit: paso 10, imagen 1 de 1
    • The vibrating unit is now removed.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 29-64, Johann Spring 2010 Miembro de Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 14
Todo El Tiempo: 1,618
