Introducción
In this guide you will learn how to remove the SD card circuit board to access the logic board. To access the logic board, you will need to unsolder two leads. For soldering instructions, please refer to steps 1 through 6 of this soldering guide.
Partes
No se requieren partes.
Remove the following screws: Two silver 3.15mm Phillips #00 screws on the right side of the camera
  • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
Agregar Comentario
Remove the two indicated screws on the bottom of the camera:
  • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
Agregar Comentario
Carefully pull the back of casing away from the front. Carefully pull the back of casing away from the front.
  • Carefully pull the back of casing away from the front.
Agregar Comentario
After removing the back cover, several things must be removed. Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”. Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  • After removing the back cover, several things must be removed.
  • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
Agregar Comentario
To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off. To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
  • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
On the front of the camera, in battery case, remove screws indicated: Two black 2.05mm Phillips #00 screws
  • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
Agregar Comentario
Flip the camera over to the backside and remove screws indicated: The screw circled in red is a longer black 3.00mm Phillips #00 screw
  • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in blue is a shorter black 2.00mm Phillips #00 screw
Agregar Comentario
Pull the cover plate off for the two power cord jacks.
  • Pull the cover plate off for the two power cord jacks.
Agregar Comentario
Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder. Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder. Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
  • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
Agregar Comentario
Remove the orange tape on top of the SD cardholder.
  • Remove the orange tape on top of the SD cardholder.
Agregar Comentario
Open the battery cover.
  • Open the battery cover.
Agregar Comentario
Lift the indicated plastic piece off. Lift the indicated plastic piece off.
  • Lift the indicated plastic piece off.
Agregar Comentario
Remove screws indicated: Two black 4.80mm Phillips #00 screws
  • Remove screws indicated:
    • Two black 4.80mm Phillips #00 screws
Agregar Comentario
Unsolder points indicated.
  • Unsolder points indicated.
  • Please refer to steps 1 through 6 of the Ifixit soldering guide to unsolder these leads.
Agregar Comentario
Carefully lift up SD cardholder to reveal logicboard. Carefully lift up SD cardholder to reveal logicboard. Carefully lift up SD cardholder to reveal logicboard.
  • Carefully lift up SD cardholder to reveal logicboard.
Agregar Comentario
Conclusión
Nicole Wong
Miembro Desde 30/01/11
329 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-29, Regan Winter 2011 Miembro de Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 1,003
