Saltar al contenido principal
ASUS Transformer Book Flip TP500LA Battery Replacement
Qué necesitas
  1. ASUS Transformer Book Flip TP500LA Battery Replacement, Back Case: paso 1, imagen 1 de 3 ASUS Transformer Book Flip TP500LA Battery Replacement, Back Case: paso 1, imagen 2 de 3 ASUS Transformer Book Flip TP500LA Battery Replacement, Back Case: paso 1, imagen 3 de 3
    • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
  2. ASUS Transformer Book Flip TP500LA Battery Replacement: paso 2, imagen 1 de 2 ASUS Transformer Book Flip TP500LA Battery Replacement: paso 2, imagen 2 de 2
    • Slide a heavy-duty spudger between the back case and the computer.
    • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Gently lift off the back case.
  3. ASUS Transformer Book Flip TP500LA Battery Replacement, Battery: paso 3, imagen 1 de 2 ASUS Transformer Book Flip TP500LA Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
    • Pull the blue tab to remove the ribbon.
  4. ASUS Transformer Book Flip TP500LA Battery Replacement: paso 4, imagen 1 de 2 ASUS Transformer Book Flip TP500LA Battery Replacement: paso 4, imagen 2 de 2
    • Remove the three 5 mm Phillips #0 screws.
    • Remove the single 6 mm Phillips #0 screw.
  5. ASUS Transformer Book Flip TP500LA Battery Replacement: paso 5, imagen 1 de 2 ASUS Transformer Book Flip TP500LA Battery Replacement: paso 5, imagen 2 de 2
    • Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
    • Gently pull the connector away from the motherboard.
    • The black 8-pin connector on the motherboard is very fragile, so be careful when removing the white 8-pin connector.
  6. ASUS Transformer Book Flip TP500LA Battery Replacement: paso 6, imagen 1 de 2 ASUS Transformer Book Flip TP500LA Battery Replacement: paso 6, imagen 2 de 2
    • Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
    • Slide the battery out from the computer to remove.
Conclusión
14 personas más completaron esta guía.
Equipo
Cal Poly, Team S13-G5, Forte Spring 2017 Miembro de Cal Poly, Team S13-G5, Forte Spring 2017
CPSU-FORTE-S17S13G5
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 51
Todo El Tiempo: 11,129
