Remove the battery, using release clips. Ensure device has no residual power by attempting boot once battery is removed.
  • Remove the battery, using release clips.
  • Ensure device has no residual power by attempting boot once battery is removed.
  • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
  • Remove HDD and RAM cover
Nueva batería = iphone mas rápido
Fix kits a partir de $16.99
Remove 7 5mm Phillips screws
  • Remove 7 5mm Phillips screws
Flip laptop and open lid. Separate the keyboard plate from the main housing, using a plastic prying tool. Being careful not to damage the LED indicators or other peripheries. Disconnect the LED, trackpad, and keyboard ribbon cables. The keyboard can now be removed
  • Flip laptop and open lid. Separate the keyboard plate from the main housing, using a plastic prying tool. Being careful not to damage the LED indicators or other peripheries.
  • Disconnect the LED, trackpad, and keyboard ribbon cables.
  • The keyboard can now be removed
Conclusión
3 personas más completaron esta guía.
Ryan
Miembro Desde 19/08/15
867 Reputación
21 Guías creadas
great help in getting to the keyboard. keyboard removal requires breaking all the securing posts , but quite easy.
just make sure there are no little bits left on assembly. also take your time and gently fold back all earth straps and insulators etc and then fold back after keyboard is fitted. didn't have one but maybe a hot glue gun would be useful to just pin a few things down.??
anyway all works well so thankyou.
dave - Contestar
with a good prying tool shouldn't break any components, i use steel guitar picks and standard plastic wedge tools to separate the parts, however glad to know this guide helped.
Ryan -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 32
Últimos 30 Días: 129
Todo El Tiempo: 2,508
