Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
  • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use both index fingers to push both spring tabs inwards towards the center of the laptop. Use both index fingers to push both spring tabs inwards towards the center of the laptop.
  • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
Agregar Comentario
With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you. Pull the battery pack up and away from you to completely free it from its recess in the case. Pull the battery pack up and away from you to completely free it from its recess in the case.
  • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
  • Pull the battery pack up and away from you to completely free it from its recess in the case.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Daniel Rodman
Miembro Desde 20/01/12
246 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-13, Maness Winter 2012 Miembro de Cal Poly, Team 8-13, Maness Winter 2012
CPSU-MANESS-W12S8G13
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 7
Todo El Tiempo: 2,077
