Saltar al contenido principal
ASUS Chromebook C300MA-DH01 Battery Replacement
Qué necesitas
  1. ASUS Chromebook C300MA-DH01 Battery  Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Battery  Replacement: paso 2, imagen 1 de 2 ASUS Chromebook C300MA-DH01 Battery  Replacement: paso 2, imagen 2 de 2
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Battery  Replacement: paso 3, imagen 1 de 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: paso 3, imagen 2 de 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: paso 3, imagen 3 de 3
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Battery  Replacement: paso 4, imagen 1 de 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: paso 4, imagen 2 de 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: paso 4, imagen 3 de 3
    • Gently detach connecting cables:
    • Carefully flip up the large black tab.
    • Carefully flip up small white tab.
    • Remove the corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
  5. ASUS Chromebook C300MA-DH01 Battery  Replacement: paso 5, imagen 1 de 2 ASUS Chromebook C300MA-DH01 Battery  Replacement: paso 5, imagen 2 de 2
    • Using the JIS-J0 Screwdriver, remove the (6) six 6 mm screws from the battery.
  6. ASUS Chromebook C300MA-DH01 Battery  Replacement: paso 6, imagen 1 de 1
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
Conclusión
amer khalil
Miembro Desde 09/26/17
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S2-G5, Passmore Fall 2017 Miembro de USF Tampa, Team S2-G5, Passmore Fall 2017
USFT-PASSMORE-F17S2G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 197
