Saltar al contenido principal
ASUS Chromebook C100PA-RBRKT07 Battery Replacement
Qué necesitas
  1. ASUS Chromebook C100PA-RBRKT07 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: paso 2, imagen 1 de 1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: paso 3, imagen 1 de 1
    • Use the T5 screwdriver to remove the 6 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: paso 4, imagen 1 de 1
    • Use the iFixit opening tool to pry the backing of the device off.
  5. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: paso 5, imagen 1 de 1
    • Use the tweezers to separate the cables from the motherboard.
    • You need to reach inside and peel some tape to disconnect the wire.
  6. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: paso 6, imagen 1 de 1
    • Use the JIS1 screwdriver to remove the four 2.1 mm screws around the audio cards.
  7. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: paso 7, imagen 1 de 2 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: paso 7, imagen 2 de 2
    • Gently disconnect the audio cards, exposing the battery.
  8. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: paso 8, imagen 1 de 1
    • Use the J00 screwdriver to remove the three 1.7 mm battery screws.
  9. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: paso 9, imagen 1 de 3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: paso 9, imagen 2 de 3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: paso 9, imagen 3 de 3
    • Grip the battery and remove it from the device.
    • Remove the battery cable out of the motherboard by lifting the battery cables.
Conclusión
Tiffany Foo
Miembro Desde 01/24/19
289 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S19-G4, White Winter 2019 Miembro de Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 374
