Saltar al contenido principal
APS Tech 101629 SCSI Connections Replacement
Qué necesitas
  1. APS Tech 101629 SCSI Connections Replacement, External Casing: paso 1, imagen 1 de 3 APS Tech 101629 SCSI Connections Replacement, External Casing: paso 1, imagen 2 de 3 APS Tech 101629 SCSI Connections Replacement, External Casing: paso 1, imagen 3 de 3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 SCSI Connections Replacement: paso 2, imagen 1 de 2 APS Tech 101629 SCSI Connections Replacement: paso 2, imagen 2 de 2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 SCSI Connections Replacement: paso 3, imagen 1 de 2 APS Tech 101629 SCSI Connections Replacement: paso 3, imagen 2 de 2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 SCSI Connections Replacement: paso 4, imagen 1 de 1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 SCSI Connections Replacement: paso 5, imagen 1 de 2 APS Tech 101629 SCSI Connections Replacement: paso 5, imagen 2 de 2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: paso 6, imagen 1 de 2 APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: paso 6, imagen 2 de 2
    • Flip so device is upside down.
    • Remove 4 screws with Phillips #1 screw driver.
    • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
  7. APS Tech 101629 SCSI Connections Replacement: paso 7, imagen 1 de 2 APS Tech 101629 SCSI Connections Replacement: paso 7, imagen 2 de 2
    • Slide the internal drive component away from the back of the device.
    • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
    • Audio Connection
    • SCSI ID
    • Terminate On
    • SCSI Connection
    • DC Input (power)
  8. APS Tech 101629 SCSI Connections Replacement, SCSI Connections: paso 8, imagen 1 de 3 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: paso 8, imagen 2 de 3 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: paso 8, imagen 3 de 3
    • Remove the four Phillips #1 Screws from back panel.
    • Once the screws are removed, the two connections are easily removed from the body.
Conclusión
Patrick Meyer
Miembro Desde 04/10/11
83 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 24-60, Amido Spring 2011 Miembro de Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 855
