Saltar al contenido principal
APS Tech 101629 Channel Switch Replacement
Qué necesitas
  1. APS Tech 101629 Channel Switch Replacement, External Casing: paso 1, imagen 1 de 3 APS Tech 101629 Channel Switch Replacement, External Casing: paso 1, imagen 2 de 3 APS Tech 101629 Channel Switch Replacement, External Casing: paso 1, imagen 3 de 3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Channel Switch Replacement: paso 2, imagen 1 de 2 APS Tech 101629 Channel Switch Replacement: paso 2, imagen 2 de 2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Channel Switch Replacement: paso 3, imagen 1 de 2 APS Tech 101629 Channel Switch Replacement: paso 3, imagen 2 de 2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Channel Switch Replacement: paso 4, imagen 1 de 1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Channel Switch Replacement: paso 5, imagen 1 de 2 APS Tech 101629 Channel Switch Replacement: paso 5, imagen 2 de 2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Channel Switch Replacement, Channel Switch: paso 6, imagen 1 de 2 APS Tech 101629 Channel Switch Replacement, Channel Switch: paso 6, imagen 2 de 2
    • Find the conjoined ID cable wires that are colored black, orange, and yellow.
    • Lift white portion of cable wires to disconnect it.
  7. APS Tech 101629 Channel Switch Replacement: paso 7, imagen 1 de 3 APS Tech 101629 Channel Switch Replacement: paso 7, imagen 2 de 3 APS Tech 101629 Channel Switch Replacement: paso 7, imagen 3 de 3
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
Conclusión
Una persona más ha completado esta guía.
Alexis Weckel
Miembro Desde 04/11/11
140 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 24-60, Amido Spring 2011 Miembro de Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 622
