Saltar al contenido principal
2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement
Qué necesitas
  1. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: paso 1, imagen 1 de 3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: paso 1, imagen 2 de 3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: paso 1, imagen 3 de 3
    • Here is the FOB for my Jeep. It decided to finally quit. The functionality became less over the last couple of weeks and required frequent attempts to unlock the vehicle etc.
    • Remove the key by moving
    • locking hatch to the left side first.
    • The two halves where the FOB needs to be split are clearly visible
  2. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: paso 2, imagen 1 de 3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: paso 2, imagen 2 de 3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: paso 2, imagen 3 de 3
    • Using a plastic opening tool (or finger nail, guitar pick etc.) start at the front of the FOB to separate it
    • Moving the tool along the split line with slight sideways pressure
    • will separate the FOB easily.
  3. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: paso 3, imagen 1 de 3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: paso 3, imagen 2 de 3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: paso 3, imagen 3 de 3
    • Here is the cleanly opened FOB
    • Bottom half of the FOB contains the CR2032 coin battery
    • Remove the battery by pulling it out of the holder pushing it gently against the spring contacts.
    • Replace the battery following the polarity with the positive side to the body of the FOB
  4. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: paso 4, imagen 1 de 2 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: paso 4, imagen 2 de 2
    • Insert wisdom here.
Conclusión
12 personas más completaron esta guía.
oldturkey03
Miembro Desde 09/29/10
783,219 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
33 Miembros
549 Guías creadas
Un comentario
Very easy! Thank you!
Cheryl Talley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 100
Ultimos 30 días: 457
Todo El Tiempo: 71,537
