Introducción
Fuses are used in electronics to protect electrical components from being exposed to excess current from the power supply. The fuse melts during a surge and breaks the circuit to protect the valuable electrical component. The element associated with a blown fuse will be disabled until the fuse is replaced.
Turn off the vehicle before beginning the fuse changing process to avoid electrocution. Pull on the lever by the driver's feet.
  • Turn off the vehicle before beginning the fuse changing process to avoid electrocution.
  • Pull on the lever by the driver's feet.
  • Move to the front of the vehicle.
  • There is a latch below the center of the hood, push it to the left.
  • Lift the hood and support it with the hood strut.
Agregar Comentario
Locate the fuse box on the driver’s side of the hood compartment.
  • Locate the fuse box on the driver’s side of the hood compartment.
  • Disengage the latch located on the side of the fuse box.
  • Swing the lid open.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Referencing the manufacturer's exterior fuse box diagram, identify the fuse that needs replacement.
  • Referencing the manufacturer's exterior fuse box diagram, identify the fuse that needs replacement.
Agregar Comentario
Carefully remove the fuse that corresponds to the electrical failure in the vehicle. Check for damage or discoloration in the fuse.
  • Carefully remove the fuse that corresponds to the electrical failure in the vehicle.
  • Check for damage or discoloration in the fuse.
  • Replace the damaged fuse with the new fuse.
  • Close the fuse box.
Agregar Comentario
Conclusión
To reassemble, follow these instructions in reverse order.
Equipo
Cal Poly, Team 15-45, Forte Fall 2012 Miembro de Cal Poly, Team 15-45, Forte Fall 2012
CPSU-FORTE-F12S15G45
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 18
Últimos 30 Días: 95
Todo El Tiempo: 4,587
