Introducción
This guide demonstrates how to remove and replace fuses for your Dodge truck.
Herramientas
Partes
Open the hood by pulling the hood lever in the driver-side footwell. Reach under the center of the grille and press the hood latch. Reach under the center of the grille and press the hood latch.
  • Open the hood by pulling the hood lever in the driver-side footwell.
  • Reach under the center of the grille and press the hood latch.
Agregar Comentario
Locate the fusebox. The fusebox is the box that says "Fuse and Relay Center", near the left front fender of your Dodge. Unscrew the plastic nut that holds the cover of the fusebox in place.
  • Locate the fusebox. The fusebox is the box that says "Fuse and Relay Center", near the left front fender of your Dodge.
  • Unscrew the plastic nut that holds the cover of the fusebox in place.
Agregar Comentario
Remove the nut and the cover of the fusebox. Use the inside of the fusebox cover to determine which fuses you need to check. Locate the fuse grabber. The fuse grabber is located near the front of the fusebox. Remove the fuse grabber from its holder.
  • Remove the nut and the cover of the fusebox. Use the inside of the fusebox cover to determine which fuses you need to check.
  • Locate the fuse grabber. The fuse grabber is located near the front of the fusebox.
  • Remove the fuse grabber from its holder.
Agregar Comentario
Use the fuse grabber to carefully pinch the fuse. Pull the desired fuse out.
  • Use the fuse grabber to carefully pinch the fuse.
  • Pull the desired fuse out.
  • Be sure to replace each blown fuse with a fuse of the correct current rating and size. Serious damage can occur if the wrong fuse is used.
Agregar Comentario
Conclusión
To replace a fuse, follow these instructions in reverse order. Make sure you buy the correct fuse to replace a blown fuse. Serious damage can occur if you do not use the correct replacement fuses.
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 3-24, Amido Fall 2012 Miembro de Cal Poly, Team 3-24, Amido Fall 2012
CPSU-AMIDO-F12S3G24
4 Miembros
8 Guías creadas
Thank you for making the instructions simple and to the point!
Sierra W - Contestar
not what i was looking for but thank you
eimerben - Contestar
thanx anyway. but not the answer I wanted. didn't tell me anything about which fuse it was .I looked in the fuse box and didn't c the fuse labled headlight there...
Marc A. Moore - Contestar
I'm trying to fine the fuse for the dashlights on a 2008 dodge ram 1500 hemi
Peggy - Contestar
Half of my fuse box only works.Wat could b wrong .I need help
Marco Polo - Contestar
Half of my fuse box only works.Wat could b the problem
il a tu une fusible pour la chauffrette si oui où elle est,merci
Robert Marcotte - Contestar
je voudrais savoir s’il a des fusibles pour la chauffrette car ce matin ma chauffrette ne marche plus merci
Where is the starter relay on a 2008? It’s not under the fuse box
daniel barber - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 54
Últimos 7 Días: 244
Últimos 30 Días: 1,279
Todo El Tiempo: 28,352
