Use a #2 Phillips screwdriver to remove the four screws.
  • Use a #2 Phillips screwdriver to remove the four screws.
Agregar Comentario
Remove the rubber gasket from the rain tray.
  • Remove the rubber gasket from the rain tray.
Agregar Comentario
Lift the tray upwards and away from the vehicle.
  • Lift the tray upwards and away from the vehicle.
Agregar Comentario
Use a flathead screwdriver to remove the cap from the windshield wiper.
  • Use a flathead screwdriver to remove the cap from the windshield wiper.
Agregar Comentario
Use a socket wrench to release the passenger-side windshield wiper locking nut.
  • Use a socket wrench to release the passenger-side windshield wiper locking nut.
Agregar Comentario
Gently lift up the passenger-side windshield wiper. Gently lift up the passenger-side windshield wiper.
  • Gently lift up the passenger-side windshield wiper.
Agregar Comentario
Remove the driver-side windshield wiper in the same fashion.
  • Remove the driver-side windshield wiper in the same fashion.
Agregar Comentario
Lift up the plastic cover. Lift up the plastic cover.
  • Lift up the plastic cover.
Agregar Comentario
Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover. In a pinch, you can make this tool with a phillips driver bit and end wrench.
  • Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
  • In a pinch, you can make this tool with a phillips driver bit and end wrench.
Agregar Comentario
Use a #2 Phillips screwdriver to remove the front two screws.
  • Use a #2 Phillips screwdriver to remove the front two screws.
Agregar Comentario
Gently unplug and lift out the automatic transmission control unit. Gently unplug and lift out the automatic transmission control unit.
  • Gently unplug and lift out the automatic transmission control unit.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Matthew Newsom
Miembro Desde 05/01/10
31,468 Reputación
93 Guías creadas
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
Paul Newlove - Contestar
does it need to be programmed mine needs replacement my gears are not shifting
dean wafula - Contestar
got a question if your display light is dim what could be the problem
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
Jusu Suapay - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 14
Últimos 7 Días: 122
Últimos 30 Días: 507
Todo El Tiempo: 28,988
