Introducción
When a car is driven, tires tend to wear unevenly. To extend the life of tires, it is important to rotate the tires every 30,000 miles. This guide will show you how to remove and rotate tires.
Herramientas
Partes
No se requieren partes.
Turn car off and remove keys from ignition.
  • Turn car off and remove keys from ignition.
  • Place car in park (automatic) or neutral (manual).
  • Engage parking brake.
Agregar Comentario
Use hydraulic jack on frame of car to raise car.
  • Use hydraulic jack on frame of car to raise car.
  • Place jack head underneath frame of car.
  • Only necessary to jack the car until the wheels are just off the ground.
Agregar Comentario
Place jack stand on frame of car and remove jack.
  • Place jack stand on frame of car and remove jack.
  • Do no work under car supported only by hydraulic jack, serious injury or death may occur.
Agregar Comentario
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use hydraulic jack on frame of car to raise car. Place jack head underneath frame couple (pictured).
  • Place jack head underneath frame couple (pictured).
Agregar Comentario
Place jack stand on frame of car and remove jack. Do not work under car supported only by hydraulic jack, serious injury or death may result.
  • Do not work under car supported only by hydraulic jack, serious injury or death may result.
Agregar Comentario
Pry off the all four hub caps by placing a small flathead screwdriver between hubcap and rim pulling the screwdriver away from tire. Pull hubcaps away from tires.
  • Pry off the all four hub caps by placing a small flathead screwdriver between hubcap and rim pulling the screwdriver away from tire.
  • Pull hubcaps away from tires.
Agregar Comentario
Loosen each of the five lug nuts on all tires by turning them counter-clockwise with a 19mm wrench.
  • Loosen each of the five lug nuts on all tires by turning them counter-clockwise with a 19mm wrench.
Agregar Comentario
Remove tires by pulling directly away from car exposing brake rotors.
  • Remove tires by pulling directly away from car exposing brake rotors.
Agregar Comentario
Swap tires according to diagram.
  • Swap tires according to diagram.
Agregar Comentario
Place tires on axels.
  • Place tires on axels.
  • Hand tighten the lug nuts with narrow end of nut towards car.
  • Finish tightening the lug nuts with 19mm Torque Wrench to a torque of 63 lb*ft.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 3-28, Regan Fall 2010 Miembro de Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 2,313
