Firstly Disconnect  battery Always take the negative terminal off first.
  • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
Agregar Comentario
Unlatch the 2 clasps. Loosen screw on metal band.
  • Unlatch the 2 clasps.
  • Loosen screw on metal band.
Agregar Comentario
Disconnect electronic sensor. Press on the 2 latches, pulling the cable away from sensor.
  • Disconnect electronic sensor.
  • Press on the 2 latches, pulling the cable away from sensor.
Agregar Comentario
Disconnect hose from MAFS. Remove MAFS.
  • Disconnect hose from MAFS.
  • Remove MAFS.
Agregar Comentario
Steps 4-6 are for cleaning only.
  • Steps 4-6 are for cleaning only.
  • Spray MAFS cleaner along direction of travel, shown by arrow.
Agregar Comentario
Clean electronic coupling with electronics cleaner. Clean electronic coupling with electronics cleaner.
  • Clean electronic coupling with electronics cleaner.
Agregar Comentario
Inject conducting lubricant into  MAFS electronic coupling. Inject conducting lubricant into  MAFS electronic coupling.
  • Inject conducting lubricant into MAFS electronic coupling.
Agregar Comentario
Re attach MAFS to air filter housing and intake hose. Tighten screw on metal band. Latch clasps on either side of MAFS.
  • Re attach MAFS to air filter housing and intake hose.
  • Tighten screw on metal band.
  • Latch clasps on either side of MAFS.
Agregar Comentario
Re attach electronic cable to MAFS.
  • Re attach electronic cable to MAFS.
Agregar Comentario
Conclusión
Isaac Nitschke
Miembro Desde 11/10/10
61 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-28, Regan Fall 2010 Miembro de Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 9
Últimos 30 Días: 44
Todo El Tiempo: 7,797
