Saltar al contenido principal
why! W670SZQ1 Replacing the LCD screen
Qué necesitas
  1. why! W670SZQ1 Replacing the LCD screen, The Batteries: paso 1, imagen 1 de 3 why! W670SZQ1 Replacing the LCD screen, The Batteries: paso 1, imagen 2 de 3 why! W670SZQ1 Replacing the LCD screen, The Batteries: paso 1, imagen 3 de 3
    • Unlock the lock latch on the left.
    • Unlock the lock latch on the right.
    • Remove the battery while holding the lock latch unlocked.
  2. why! W670SZQ1 Replacing the LCD screen, LCD screen: paso 2, imagen 1 de 3 why! W670SZQ1 Replacing the LCD screen, LCD screen: paso 2, imagen 2 de 3 why! W670SZQ1 Replacing the LCD screen, LCD screen: paso 2, imagen 3 de 3
    • Start by locating the two screw caps on the left side of the screen.
    • Remove the lower screw cover.
    • Then the top screw cover.
  3. why! W670SZQ1 Replacing the LCD screen: paso 3, imagen 1 de 3 why! W670SZQ1 Replacing the LCD screen: paso 3, imagen 2 de 3 why! W670SZQ1 Replacing the LCD screen: paso 3, imagen 3 de 3
    • Locate and then remove the first center screw on the top of the screen frame.
    • Then the second central cap on the top of the screen frame.
    • Then locate and remove the screw cap on the upper right side of the screen frame.
  4. why! W670SZQ1 Replacing the LCD screen: paso 4, imagen 1 de 3 why! W670SZQ1 Replacing the LCD screen: paso 4, imagen 2 de 3 why! W670SZQ1 Replacing the LCD screen: paso 4, imagen 3 de 3
    • Then finally the bottom right screw cap of the screen frame.
    • Then unscrew the screws behind the screw caps, starting with the one at the bottom left of the frame.
    • Then at the top left.
  5. why! W670SZQ1 Replacing the LCD screen: paso 5, imagen 1 de 3 why! W670SZQ1 Replacing the LCD screen: paso 5, imagen 2 de 3 why! W670SZQ1 Replacing the LCD screen: paso 5, imagen 3 de 3
    • Then the first central screw on the top edge of the frame.
    • Then the second central screw on the top edge of the frame.
    • Then the one in the upper right corner of the frame.
  6. why! W670SZQ1 Replacing the LCD screen: paso 6, imagen 1 de 3 why! W670SZQ1 Replacing the LCD screen: paso 6, imagen 2 de 3 why! W670SZQ1 Replacing the LCD screen: paso 6, imagen 3 de 3
    • And finally the one on the lower right side of the frame.
    • Then gently use your nails.
    • To remove the frame from the LCD screen.
  7. why! W670SZQ1 Replacing the LCD screen: paso 7, imagen 1 de 3 why! W670SZQ1 Replacing the LCD screen: paso 7, imagen 2 de 3 why! W670SZQ1 Replacing the LCD screen: paso 7, imagen 3 de 3
    • Unscrew the screws on the front of the LCD screen.
    • Next, unscrew the screws on the right side of the LCD screen, starting with the first one.
    • Then the second.
  8. why! W670SZQ1 Replacing the LCD screen: paso 8, imagen 1 de 3 why! W670SZQ1 Replacing the LCD screen: paso 8, imagen 2 de 3 why! W670SZQ1 Replacing the LCD screen: paso 8, imagen 3 de 3
    • Then the third.
    • And finally the fourth.
    • Repeat these operations then on the left side of the screen starting with the first screw.
  9. why! W670SZQ1 Replacing the LCD screen: paso 9, imagen 1 de 3 why! W670SZQ1 Replacing the LCD screen: paso 9, imagen 2 de 3 why! W670SZQ1 Replacing the LCD screen: paso 9, imagen 3 de 3
    • Then the second.
    • Then the third. .
  10. why! W670SZQ1 Replacing the LCD screen: paso 10, imagen 1 de 3 why! W670SZQ1 Replacing the LCD screen: paso 10, imagen 2 de 3 why! W670SZQ1 Replacing the LCD screen: paso 10, imagen 3 de 3
    • Then flip the LCD screen.
    • Then appears the connector to which is attached the connection cable of the LCD.
    • Then peel off the tape covering the connector.
  11. why! W670SZQ1 Replacing the LCD screen: paso 11, imagen 1 de 3 why! W670SZQ1 Replacing the LCD screen: paso 11, imagen 2 de 3 why! W670SZQ1 Replacing the LCD screen: paso 11, imagen 3 de 3
    • then remove the cable from its connector.
    • Once the cable is disconnected you can release the LCD screen.
Conclusión
to reassemble your device follow these instructions in reverse order.
Un agradecimiento especial a estos traductores:
fr en
100%
¡ irlanda nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,028 Reputación
244 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 120
