Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
  1. Open the latch of the accumulator on the left side. Open the battery latch on the right side. Remove the accumulator by simultaneously holding the right-hand latch open.
    • Open the latch of the accumulator on the left side.
    • Open the battery latch on the right side.
    • Remove the accumulator by simultaneously holding the right-hand latch open.
  2. Kit de Destornilladores Manta
    112 bits for every fix.
    Upgrade Your Toolbox
  3. Use the Philips screwdriver to remove the two screws at the bottom of the cover. Lift the cover at the bottom right with the iFixit Opening Tool Lift the cover at the bottom left with the iFixit Opening Tool
    • Use the Philips screwdriver to remove the two screws at the bottom of the cover.
    • Lift the cover at the bottom right with the iFixit Opening Tool
    • Lift the cover at the bottom left with the iFixit Opening Tool
    • Finally, remove the cover to gain access to the most important components.
  4. With a Philips screwdriver, remove the 4 mounting screws of the heat sink. Now remove the heat sink. Once the heat sink is removed you can see the processor with its lock. Unlock the processor and remove it from its socket.
    • With a Philips screwdriver, remove the 4 mounting screws of the heat sink.
    • Now remove the heat sink. Once the heat sink is removed you can see the processor with its lock.
    • Unlock the processor and remove it from its socket.
Conclusión
Repeat the steps in reverse order to reassemble your device.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 15/06/13
14,874 Reputación
150 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 44
