Saltar al contenido principal
why! W670SZQ1 Keyboard Replacement
Qué necesitas
  1. why! W670SZQ1 Keyboard Replacement, The Batteries: paso 1, imagen 1 de 3 why! W670SZQ1 Keyboard Replacement, The Batteries: paso 1, imagen 2 de 3 why! W670SZQ1 Keyboard Replacement, The Batteries: paso 1, imagen 3 de 3
    • Unlock the lock latch on the left.
    • Unlock the lock latch on the right.
    • Remove the battery while holding the lock latch unlocked.
  2. why! W670SZQ1 Keyboard Replacement, Access to Major Components: paso 2, imagen 1 de 3 why! W670SZQ1 Keyboard Replacement, Access to Major Components: paso 2, imagen 2 de 3 why! W670SZQ1 Keyboard Replacement, Access to Major Components: paso 2, imagen 3 de 3
    • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
    • Lift the bottom right cover with the iFixit Opening Tool.
    • Lift the lower left cover with the iFixit Opening Tool.
    • Finally clear the bottom cover completely to access the main components.
  3. why! W670SZQ1 Keyboard Replacement, The keyboard: paso 3, imagen 1 de 3 why! W670SZQ1 Keyboard Replacement, The keyboard: paso 3, imagen 2 de 3 why! W670SZQ1 Keyboard Replacement, The keyboard: paso 3, imagen 3 de 3
    • Once the bottom cover is removed you can start disassembling the keyboard.
    • Start by turning the computer over and then unscrew the screw shown in image 2 of this step.
    • Then using the screwdriver unscrew the bar that hides the screws fixing the keyboard.
  4. why! W670SZQ1 Keyboard Replacement: paso 4, imagen 1 de 3 why! W670SZQ1 Keyboard Replacement: paso 4, imagen 2 de 3 why! W670SZQ1 Keyboard Replacement: paso 4, imagen 3 de 3
    • Once the bar hiding the fixing screws of the keyboard is unclipped we see the tip of the screwdriver.
    • Now find the 5 screws fixing the keyboard.
    • Unscrew the 5 screws.
  5. why! W670SZQ1 Keyboard Replacement: paso 5, imagen 1 de 3 why! W670SZQ1 Keyboard Replacement: paso 5, imagen 2 de 3 why! W670SZQ1 Keyboard Replacement: paso 5, imagen 3 de 3
    • Now gently lift the keyboard.
    • Then appear the keyboard connection cable and the keyboard backlight cable
    • Start by unlocking the right latch of the connector securing the backlight cable.
  6. why! W670SZQ1 Keyboard Replacement: paso 6, imagen 1 de 3 why! W670SZQ1 Keyboard Replacement: paso 6, imagen 2 de 3 why! W670SZQ1 Keyboard Replacement: paso 6, imagen 3 de 3
    • Then the one on the left.
    • Do the same with the left latch of the connector securing the main cable.
    • Then with the right latch of the connector fixing the main cable.
  7. why! W670SZQ1 Keyboard Replacement: paso 7, imagen 1 de 1
    • Then remove the keyboard from its location.
Conclusión
To reassemble your device, Follow these instructions in reverse order.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
¡ irlanda nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,055 Reputación
245 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 142
