Saltar al contenido principal
why! W670SZQ1 BIOS Replacement Battery
Qué necesitas
  1. why! W670SZQ1 BIOS Replacement Battery, The Batteries: paso 1, imagen 1 de 3 why! W670SZQ1 BIOS Replacement Battery, The Batteries: paso 1, imagen 2 de 3 why! W670SZQ1 BIOS Replacement Battery, The Batteries: paso 1, imagen 3 de 3
    • Unlock the lock latch on the left.
    • Unlock the lock latch on the right.
    • Remove the battery while holding the lock latch unlocked.
  2. why! W670SZQ1 BIOS Replacement Battery, Access to Major Components: paso 2, imagen 1 de 3 why! W670SZQ1 BIOS Replacement Battery, Access to Major Components: paso 2, imagen 2 de 3 why! W670SZQ1 BIOS Replacement Battery, Access to Major Components: paso 2, imagen 3 de 3
    • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
    • Lift the bottom right cover with the iFixit Opening Tool.
    • Lift the lower left cover with the iFixit Opening Tool.
    • Finally clear the bottom cover completely to access the main components.
  3. why! W670SZQ1 BIOS Replacement Battery, The BIOS stack: paso 3, imagen 1 de 1
    • Lift and carefully remove the battery from its holder.
    • Do not put the battery in the trash. In Switzerland, all businesses in the electronics and home appliance sector are required to take back batteries and accumulators for recycling
Conclusión
To reassemble your device, follow the instructions in reverse order.
Un agradecimiento especial a estos traductores:
fr en
100%
¡ Israel nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,055 Reputación
245 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 88
