Saltar al contenido principal
why! W650SZ LCD Screen Replacement
Qué necesitas
  1. why! W650SZ LCD Screen Replacement, Battery: paso 1, imagen 1 de 3 why! W650SZ LCD Screen Replacement, Battery: paso 1, imagen 2 de 3 why! W650SZ LCD Screen Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the latch on the right to the unlocked position.
    • Slide the latch on the left to the unlocked position.
    • Remove the battery pack from the slot.
  2. why! W650SZ LCD Screen Replacement, Remove the Bezel: paso 2, imagen 1 de 3 why! W650SZ LCD Screen Replacement, Remove the Bezel: paso 2, imagen 2 de 3 why! W650SZ LCD Screen Replacement, Remove the Bezel: paso 2, imagen 3 de 3
    • Although the photos are shown without a keyboard, it is not necessary to remove the keyboard to replace the screen.
    • Gently insert your fingernail between the display bezel and the LCD.
  3. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): paso 3, imagen 1 de 3 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): paso 3, imagen 2 de 3 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): paso 3, imagen 3 de 3
    • Working your way around the frame, unclip the mounting points of the frame surrounding the LCD screen.
  4. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): paso 4, imagen 1 de 3 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): paso 4, imagen 2 de 3 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): paso 4, imagen 3 de 3
    • Remove the bezel surrounding the LCD.
  5. why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: paso 5, imagen 1 de 3 why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: paso 5, imagen 2 de 3 why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: paso 5, imagen 3 de 3
    • Remove the two upper mounting screws securing the LCD to the lid.
    • Remove the two lower mounting screws.
  6. why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: paso 6, imagen 1 de 3 why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: paso 6, imagen 2 de 3 why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: paso 6, imagen 3 de 3
    • Cover the keyboard with a cloth, then carefully lower the LCD screen onto the keyboard.
  7. why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: paso 7, imagen 1 de 3 why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: paso 7, imagen 2 de 3 why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: paso 7, imagen 3 de 3
    • Note the location of the LCD screen connector.
  8. why! W650SZ LCD Screen Replacement, Remove the Connector Tape: paso 8, imagen 1 de 3 why! W650SZ LCD Screen Replacement, Remove the Connector Tape: paso 8, imagen 2 de 3 why! W650SZ LCD Screen Replacement, Remove the Connector Tape: paso 8, imagen 3 de 3
    • Using the plastic tab, peel back the tape securing the LCD cable the panel connector.
  9. why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: paso 9, imagen 1 de 3 why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: paso 9, imagen 2 de 3 why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: paso 9, imagen 3 de 3
    • Unplug the connector.
    • The LCD screen can now be removed.
Conclusión
Un agradecimiento especial a estos traductores:
fr en
100%
¡ Jerry Wheeler nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,028 Reputación
245 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 129
