Saltar al contenido principal
why! W650SZ Keyboard Replacement
Qué necesitas
  1. why! W650SZ Keyboard Replacement, Battery: paso 1, imagen 1 de 3 why! W650SZ Keyboard Replacement, Battery: paso 1, imagen 2 de 3 why! W650SZ Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the latch on the right to the unlocked position.
    • Slide the latch on the left to the unlocked position.
    • Remove the battery pack from the slot.
  2. why! W650SZ Keyboard Replacement, why! W650SZ Bottom Cover Replacement: paso 2, imagen 1 de 3 why! W650SZ Keyboard Replacement, why! W650SZ Bottom Cover Replacement: paso 2, imagen 2 de 3 why! W650SZ Keyboard Replacement, why! W650SZ Bottom Cover Replacement: paso 2, imagen 3 de 3
    • With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
    • Now you can remove the bottom cover.
  3. why! W650SZ Keyboard Replacement, Keyboard: paso 3, imagen 1 de 3 why! W650SZ Keyboard Replacement, Keyboard: paso 3, imagen 2 de 3 why! W650SZ Keyboard Replacement, Keyboard: paso 3, imagen 3 de 3
    • Press gently at the points indicated to release the LED cover strip.
    • Turn the laptop over, then lift the LED cover.
    • Remove the LED cover.
  4. why! W650SZ Keyboard Replacement: paso 4, imagen 1 de 3 why! W650SZ Keyboard Replacement: paso 4, imagen 2 de 3 why! W650SZ Keyboard Replacement: paso 4, imagen 3 de 3
    • The five screws that anchor the keyboard are now visible.
    • Start by removing the first screw.
    • Remove the remaining screws (2-5).
  5. why! W650SZ Keyboard Replacement: paso 5, imagen 1 de 3 why! W650SZ Keyboard Replacement: paso 5, imagen 2 de 3 why! W650SZ Keyboard Replacement: paso 5, imagen 3 de 3
    • Dismount the keyboard from the chassis.
    • Flip the keyboard forward, taking care as it is still connected by a cable to the motherboard.
    • Release the cable latch on the right side of the motherboard connector with a small flat blade screwdriver.
  6. why! W650SZ Keyboard Replacement: paso 6, imagen 1 de 3 why! W650SZ Keyboard Replacement: paso 6, imagen 2 de 3 why! W650SZ Keyboard Replacement: paso 6, imagen 3 de 3
    • Release the cable latch on the left side of the motherboard connector.
    • Slide the cable straight out from its connector.
    • Remove the keyboard.
Conclusión
Un agradecimiento especial a estos traductores:
fr en
100%
¡ Jerry Wheeler nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,028 Reputación
245 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 128
