Saltar al contenido principal
why! N650DU Motherboard
Qué necesitas
  1. why! N650DU Motherboard, The Batteries: paso 1, imagen 1 de 3 why! N650DU Motherboard, The Batteries: paso 1, imagen 2 de 3 why! N650DU Motherboard, The Batteries: paso 1, imagen 3 de 3
    • Unlock the button without spring
    • Slide the battery up while unlocking the button with spring
  2. why! N650DU Motherboard, Access to major components: paso 2, imagen 1 de 3 why! N650DU Motherboard, Access to major components: paso 2, imagen 2 de 3 why! N650DU Motherboard, Access to major components: paso 2, imagen 3 de 3
    • Unscrew the two large screws circled in red
    • Unscrew the two small screws circled in green
    • Slide the plate down and lift the
  3. why! N650DU Motherboard, RAM memory: paso 3, imagen 1 de 3 why! N650DU Motherboard, RAM memory: paso 3, imagen 2 de 3 why! N650DU Motherboard, RAM memory: paso 3, imagen 3 de 3
    • Spread the two arms holding the RAM bar
    • Remove the RAM card
  4. why! N650DU Motherboard, SSD disk: paso 4, imagen 1 de 2 why! N650DU Motherboard, SSD disk: paso 4, imagen 2 de 2
    • Unscrew the screw circled in red
    • Remove the SSD
  5. why! N650DU Motherboard, Hard disk: paso 5, imagen 1 de 3 why! N650DU Motherboard, Hard disk: paso 5, imagen 2 de 3 why! N650DU Motherboard, Hard disk: paso 5, imagen 3 de 3
    • Pull the black tab up
  6. why! N650DU Motherboard, CD / DVD RW drive: paso 6, imagen 1 de 3 why! N650DU Motherboard, CD / DVD RW drive: paso 6, imagen 2 de 3 why! N650DU Motherboard, CD / DVD RW drive: paso 6, imagen 3 de 3
    • Push the drive to the location indicated by the green arrow
    • Remove the drive from its location
  7. why! N650DU Motherboard, Carte WLAN: paso 7, imagen 1 de 3 why! N650DU Motherboard, Carte WLAN: paso 7, imagen 2 de 3 why! N650DU Motherboard, Carte WLAN: paso 7, imagen 3 de 3
    • Disconnect the WLAN card in the direction of the red arrow
    • Unhook the two connectors circled in green on the WLAN card
  8. why! N650DU Motherboard, Processor: paso 8, imagen 1 de 3 why! N650DU Motherboard, Processor: paso 8, imagen 2 de 3 why! N650DU Motherboard, Processor: paso 8, imagen 3 de 3
    • Unscrew the four screws circled in red
    • Lift the radiator with the black label
  9. why! N650DU Motherboard: paso 9, imagen 1 de 3 why! N650DU Motherboard: paso 9, imagen 2 de 3 why! N650DU Motherboard: paso 9, imagen 3 de 3
    • Push the lever in the direction of the red arrow while pushing it in
    • Lift the lever in the direction of the green arrow
    • Do not touch the bottom of the processor and take it by the sides
  10. why! N650DU Motherboard, The fan: paso 10, imagen 1 de 3 why! N650DU Motherboard, The fan: paso 10, imagen 2 de 3 why! N650DU Motherboard, The fan: paso 10, imagen 3 de 3
    • Unscrew the two screws circled in red
    • Disconnect the connector surrounded in green
    • Remove the fan by lifting the blue framed tab
  11. why! N650DU Motherboard, Pile BIOS: paso 11, imagen 1 de 2 why! N650DU Motherboard, Pile BIOS: paso 11, imagen 2 de 2
    • Remove the battery using a flat screwdriver
  12. why! N650DU Motherboard, The keyboard: paso 12, imagen 1 de 3 why! N650DU Motherboard, The keyboard: paso 12, imagen 2 de 3 why! N650DU Motherboard, The keyboard: paso 12, imagen 3 de 3
    • Unscrew the circled screws in red and green
    • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
    • Lift the keyboard
  13. why! N650DU Motherboard: paso 13, imagen 1 de 3 why! N650DU Motherboard: paso 13, imagen 2 de 3 why! N650DU Motherboard: paso 13, imagen 3 de 3
    • Remove the red circled connector
    • Pull the white drawer that holds the connector circled in blue in the direction of the green arrow
    • Remove the connector surrounded in blue
  14. why! N650DU Motherboard, Motherboard: paso 14, imagen 1 de 3 why! N650DU Motherboard, Motherboard: paso 14, imagen 2 de 3 why! N650DU Motherboard, Motherboard: paso 14, imagen 3 de 3
    • Lift the two black flaps
    • Remove the two connectors circled in red
  15. why! N650DU Motherboard: paso 15, imagen 1 de 3 why! N650DU Motherboard: paso 15, imagen 2 de 3 why! N650DU Motherboard: paso 15, imagen 3 de 3
    • Remove the thirteen screws circled in red
    • Remove the top cover
  16. why! N650DU Motherboard: paso 16, imagen 1 de 3 why! N650DU Motherboard: paso 16, imagen 2 de 3 why! N650DU Motherboard: paso 16, imagen 3 de 3
    • Lift the blue flap that holds the connector circled in green
    • Disconnect the red circled connector
  17. why! N650DU Motherboard: paso 17, imagen 1 de 3 why! N650DU Motherboard: paso 17, imagen 2 de 3 why! N650DU Motherboard: paso 17, imagen 3 de 3
    • Disconnect the two connectors located in the green zone
    • Disconnect the connector surrounded in blue
  18. why! N650DU Motherboard: paso 18, imagen 1 de 3 why! N650DU Motherboard: paso 18, imagen 2 de 3 why! N650DU Motherboard: paso 18, imagen 3 de 3
    • Remove the Micro SD port cover that is circled in green if there is one
    • Unscrew the three screws circled in red
    • Carefully remove the motherboard
Conclusión
To reassemble your device, follow the instructions in reverse order.
Un agradecimiento especial a estos traductores:
fr en
100%
¡ irlanda nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,028 Reputación
244 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 494
