Saltar al contenido principal
why! N240JU Replacing the WLAN Card
Qué necesitas
  1. why! N240JU Replacing the WLAN Card, Battery: paso 1, imagen 1 de 2 why! N240JU Replacing the WLAN Card, Battery: paso 1, imagen 2 de 2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240JU Replacing the WLAN Card, Access to main components: paso 2, imagen 1 de 2 why! N240JU Replacing the WLAN Card, Access to main components: paso 2, imagen 2 de 2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240JU Replacing the WLAN Card: paso 3, imagen 1 de 3 why! N240JU Replacing the WLAN Card: paso 3, imagen 2 de 3 why! N240JU Replacing the WLAN Card: paso 3, imagen 3 de 3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240JU Replacing the WLAN Card, WLAN card: paso 4, imagen 1 de 2 why! N240JU Replacing the WLAN Card, WLAN card: paso 4, imagen 2 de 2
    • Carefully unplug the MAIN and AUX antennas.
    • Unscrew the fixing screw with the Philips # 0 screwdriver. Then lift the chipset slightly and remove it from the connector.
Conclusión
To reassemble your device, follow the instructions in reverse order.
Un agradecimiento especial a estos traductores:
fr en
100%
¡ Israel nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,028 Reputación
245 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 151
