Saltar al contenido principal
why! N240JU Hard disk replacement (mass storage)
Qué necesitas
  1. why! N240JU Hard disk replacement (mass storage), Battery: paso 1, imagen 1 de 2 why! N240JU Hard disk replacement (mass storage), Battery: paso 1, imagen 2 de 2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240JU Hard disk replacement (mass storage), Access to main components: paso 2, imagen 1 de 2 why! N240JU Hard disk replacement (mass storage), Access to main components: paso 2, imagen 2 de 2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240JU Hard disk replacement (mass storage): paso 3, imagen 1 de 3 why! N240JU Hard disk replacement (mass storage): paso 3, imagen 2 de 3 why! N240JU Hard disk replacement (mass storage): paso 3, imagen 3 de 3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240JU Hard disk replacement (mass storage), Hard disk (mass storage): paso 4, imagen 1 de 3 why! N240JU Hard disk replacement (mass storage), Hard disk (mass storage): paso 4, imagen 2 de 3 why! N240JU Hard disk replacement (mass storage), Hard disk (mass storage): paso 4, imagen 3 de 3
    • Locate the hard drive in its location.
    • Lift it slightly.
    • Finally remove it from its SATA connector.
Conclusión
To reassemble your device, Follow these instructions in reverse order.
Un agradecimiento especial a estos traductores:
fr en
100%
¡ irlanda nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,028 Reputación
245 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 238
