Saltar al contenido principal
why! N240BU Keyboard Replacement
Qué necesitas
  1. why! N240BU Keyboard Replacement, Battery: paso 1, imagen 1 de 2 why! N240BU Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240BU Keyboard Replacement, Access to main components: paso 2, imagen 1 de 2 why! N240BU Keyboard Replacement, Access to main components: paso 2, imagen 2 de 2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240BU Keyboard Replacement: paso 3, imagen 1 de 3 why! N240BU Keyboard Replacement: paso 3, imagen 2 de 3 why! N240BU Keyboard Replacement: paso 3, imagen 3 de 3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240BU Keyboard Replacement, The keyboard: paso 4, imagen 1 de 3 why! N240BU Keyboard Replacement, The keyboard: paso 4, imagen 2 de 3 why! N240BU Keyboard Replacement, The keyboard: paso 4, imagen 3 de 3
    • Unscrew the circled screws in green and red
    • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
    • Lift the keyboard
  5. why! N240BU Keyboard Replacement: paso 5, imagen 1 de 3 why! N240BU Keyboard Replacement: paso 5, imagen 2 de 3 why! N240BU Keyboard Replacement: paso 5, imagen 3 de 3
    • Disconnect the connector circled in red in the direction of the arrow
Conclusión
3 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,028 Reputación
244 Guías creadas
2 comentarios
Thanks for the example. But where did you bought the keyboard? i can’t find it.
Marcos - Contestar
Dear Sir,
thank you for your request. We are swiss keyboards, which you can order here:
''https://whyopencomputing.ch/fr/laptop-wh...
and we have a French AZERTY here:
''https://whyopencomputing.com/fr/laptop-w...
For other keyboards, please try by your local Clevo supplier.
Best regards.
Felice Suglia - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 315
